dzVents - how to start / install?
renerene
Post by renerene »
If installed the latest beta version Domotic, versions V3.8125.
If have unchecked the box 'disable dzVentz' in settings and added the test script from https://github.com/dannybloe/dzVents. After saving the test script in the build-in domoticz editor the log shows:
2017-07-25 16:28:28.341 EventSystem: reset all events...
2017-07-25 16:28:28.353 EventSystem: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dzTest.lua
But after switching the dummy switch: nothing.
also adding extra print or domoticz.notify commands don't show in the log
How to start with dzvents? Is it built in, or do have to download anyththing from github?
Other settings to check?
dannybloe
Re: dzVents - how to start / install?
Post by dannybloe »
Hi renerene.
First of all, there's a dzVents sub-forum in the Lua form. Next time you can use that.
Second, check the documentation > getting started (don't use my old github page coz that is old dzVents and has a slightly different syntax).
Documentation
dzVents forum
renerene
Post by renerene »
thank you Will put future posts in the correct section.
For now gettin hopeless. 127.0.0.1 is in Local Networks (settings)
1) nog log messages
2) on purpose there is a typo mistake: no syntax error in log
    	active = true,
    		'dummy'
    		if (switch.state == 'On') then
                prdfsgint ('On')
    		    domoticz.log('Off')
result:
2017-07-25 19:57:50.408 (stroommeter-USB1) P1 Smart Meter (Stroom)
2017-07-25 19:57:55.810 User: hegge30 initiated a switch command (804/dummy/On)
2017-07-25 19:57:57.170 (Dummy) Light/Switch (dummy)
2017-07-25 19:57:57.222 (RFlink) Temp + Humidity (RFLINK-badkamer thermo hygro sensor)
dannybloe
Post by dannybloe »
Did you also mark the script as active using the checkbox 'Event active' in the web editor?
Screen Shot 2017-07-25 at 20.09.14.png (29.3 KiB) Viewed 2029 times
and
prdfsgint ('On')
doesn't seem right to me.
randytsuch
Post by randytsuch »
On statement appears to be incorrect
    active = true,
        devices = {
            'Room switch'
    execute = function(domoticz, roomSwitch)
        if (roomSwitch.state == 'On' and domoticz.devices('Living room').temperature > 18) then
            domoticz.devices('Another switch').switchOn()
            domoticz.notify('This rocks!',
                            'Turns out that it is getting warm here',
                            domoticz.PRIORITY_LOW)
dannybloe
Post by dannybloe »
Ah, good catch. Old syntax indeed.
So please read the getting started and watch the getting started video (see dzVents subforum, first post).
renerene
Post by renerene »
UPDATE - SOLVED
Yes, it works. My first steps in dzVents.
New questions will be post in correct forum subfolder
	active = true,
		devices = {'dummy'}
	    domoticz.log ('Hello???')
            domoticz.log ('On')
    	    domoticz.log('Off')
