I have just received my new multisensor Fibaro FGMS-001. Included in the network by using the Aoen z-stick gen 5. This was succesfull
However when I look at the node list the node is unknown and in probe (sleeping) state. See attachment.
I have read this state is normal because it is a battery powered sensor. But when I trigger the motion sensor still nothing happens in domoticz.
In the OZW_log I see the following:
2017-07-21 15:59:20.261 Info, Node008, ApplicationCommandHandler - Unhandled Command Class 0x71
2017-07-21 16:00:02.797 Warning, WARNING: Out of frame flow! (0x05). Sending NAK.
2017-07-21 16:00:02.799 Detail, Node008, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x08, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x01, 0x08, 0x6c
2017-07-21 16:00:02.800 Info, Node008, ApplicationCommandHandler - Unhandled Command Class 0x71
Any idea how to get my sensor recognized correctly by Domoticz?
Fibaro FGMS-001 not recognized
- Domoticz.png (156.57 KiB) Viewed 931 times
Re: Fibaro FGMS-001 not recognized
this does not seem to be added properly, have you tried to exclude and include again?
Yes I just excluded and included to the network again. Reconnected the USB stick, but still no difference unfortunately.
Now I tried it through the domoticz interface (not with the USB stick) to include and it was succesfully recognized.
