However I just added another D1 mini powered device that shows the weather conditions from the weather underground plugin, when it gets updated the details are pushed to MQTT, the D1 is subscribed to Domoticz/out and picks up the update parses out the IDX to check its the right device and updates the temp, humidity, pressure and dew point on it's LCD screen. This also works OK until I activate the sonoff toggle device then the weather display just stops working.
If I am monitoring the com port I can see all MQTT messages coming from Domoticz until the sonoff toggle D1 is triggered then just nothing.
I put the weather display on a static IP in case they were both getting the same address for some reason but no difference.
Also when I first had both running they somehow interacted and sent the sonoff plug into a MQTT toggle frenzy, but I stopped that with some code changes.
Whatever is happening seems to occur before the MQTT updtae for the switch is sent out from Domoticz as the weather device does not show the update before stopping working.
Oh I can still see the weather device on the network and ping it when its stopped.
Here is the weather device code
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
// For LCD
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
const char* ssid = "ssid";
const char* password = "password";
const char* mqtt_server = "192.168.0.39";
const String domoticzID = "60"; // idx of weather underground
IPAddress arduino_ip ( 192, 168, 0, 150);
IPAddress gateway_ip ( 192, 168, 0, 1);
IPAddress subnet_mask(255, 255, 255, 0);
String data = ""; // String with json data
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
Serial.begin(115200);
delay(10);
lcd.init(); // initialize the lcd
//lcd.init();
// Print a message to the LCD.
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Warming UP!");
delay(1000);
lcd.clear();
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
//Serial.println("Subscribing");
//client.subscribe("domoticz/out");
yield();
if (!client.connected()) {
reconnect();
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
lcd.print("Connecting to ");
lcd.setCursor(0, 1);
lcd.print(ssid);
WiFi.config(arduino_ip, gateway_ip, subnet_mask);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
lcd.clear();
lcd.print("IP Address");
lcd.print(WiFi.localIP());
delay(4000);
lcd.clear();
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
DynamicJsonBuffer jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(payload);
if (!root.success())
Serial.println("parseObject() failed");
return;
int idx = root["idx"];
if (String(idx) == domoticzID) {
float temperature = root["svalue1"];
int humidity = root["svalue2"];
int pressure = root["svalue4"];
float dewpoint = (temperature - ((100 - humidity) / 5));
int cursorloc = 9;
int dewLoc = 6;
if (pressure < 1000) {
int cursorloc = 10;
if (dewpoint < 10.00) {
int dewLoc = 7;
Serial.println(idx);
Serial.println(temperature);
Serial.println(humidity);
// but actually the LED is on; this is because
// it is acive low on the ESP-01)
lcd.clear();
lcd.print(temperature);
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(cursorloc, 0);
lcd.print(pressure);
lcd.print("hPa");
lcd.print(humidity);
lcd.print("%");
lcd.setCursor(dewLoc, 1);
lcd.print("Dew");
lcd.print(dewpoint);
lcd.print("C");
else{
Serial.println("IDX Not relevant");
delay(500);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
lcd.clear();
lcd.print("Connect to MQTT");
// Attempt to connect
if (client.connect("ESP8266Client")) {
Serial.println("connected");
// Once connected, publish an announcement...
String payload = "{\"command\": \"getdeviceinfo\", \"idx\": " + domoticzID + "}";
client.publish("domoticz/in", payload.c_str());
// ... and resubscribe
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
delay(10);
void loop() {
delay(10);
client.loop();
}Code: Select all
// Update these with values suitable for your network.
const String domoticzID = "69";
long lastMsg = 0;
char msg[50];
int value = 0;
int tryCount = 0;
//For battery voltage
unsigned int raw = 0;
float volt = 0.0;
void setup() {
Serial.setTimeout(2000);
// Wait for serial to initialize.
while (!Serial) { }
Serial.println("Device Started");
Serial.println("-------------------------------------");
Serial.println("Running Deep Sleep Firmware!");
setup_wifi();
reconnect();
void setup_wifi() {
delay(10);
Serial.println();
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("] ");
Serial.println();
StaticJsonBuffer<200> jsonBuffer;
return;
String switchType = root["switchType"];
Serial.println(switchType);
if (String(idx) == domoticzID && switchType == "On/Off") {
Serial.println("Entering deep sleep mode");
ESP.deepSleep(0, WAKE_RF_DEFAULT); // infinite deepsleep
} else {
Serial.println("No repy received");
delay(500);
if(tryCount <= 2) {
reconnect();
else{
void reconnect() {
// Get battery Voltage
raw = analogRead(A0);
volt = raw / 1023.0;
volt = volt * 4.5;
Serial.print(volt);
Serial.println("V");
unsigned char level = map((volt * 1000), 3000, 4200, 0, 100);
Serial.print(level);
Serial.println("%");
String payload = "{\"command\": \"switchlight\", \"idx\": " + domoticzID + ", \"switchcmd\": \"Toggle\", \"Battery\": " + level + "}";
client.publish("domoticz/in", (char*) payload.c_str());
Serial.println("Message sent");
Serial.println(payload);
} else {
delay(5000);
tryCount += 1;
void loop() {
client.loop();
