What is wrong with my parantheses?
havnegata
Domoticz version: V4.10162
Post by havnegata »
Raspberry Pi
V3.8035
There are two motion sensors, one virtual switch and a group of lights, and this script gives me the error:
scripts/lua/script_device_lysPåNatt.lua:3: 'then' expected near ')'
What's wrong with the parantheses?
if ((devicechanged['Bevegelse Neo'] == 'On') or (devicechanged['Bevegelse'] == 'Motion')) and ((otherdevices['Natta']) == 'On') and (otherdevices['Group:Lys stue']) == 'On')) then
		commandArray['TomStue']='Off'
		print ("Noen har våknet og lyset er på igjen")
if (uservariables['Natta'] == 0) then
		commandArray['SendNotification']='Noen har våknet og lyset er på igjen'
		commandArray['Variable:Natta']=tostring (1)
Doler
Re: What is wrong with my parantheses?
Post by Doler »
...((otherdevices['Natta']) == 'On')...
There is a closing parenthesis too much just after ['Natta'].
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
K3rryBlue
Domoticz version: V4.10xx
Post by K3rryBlue »
Please use corrected code below.
There are 2 errors with parantheses. Use notepad++, it will help you detecting the error.
if ((devicechanged['Bevegelse Neo'] == 'On') or (devicechanged['Bevegelse'] == 'Motion')) and ( (otherdevices['Natta'] == 'On') and (otherdevices['Group:Lys stue'] == 'On')) then
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
havnegata
Post by havnegata »
Thanks both of you! Works perfectly now
Sent from my Nexus 6P using Tapatalk
