Page 1 of 3
Dashticz - Function - RGB-support
Posted: Tuesday 11 July 2017 22:00
by robgeerts
Now it is possible to control your hue RGB-lamps..
I've found out that Domoticz doesnt return the current value so I save the last picked color to a cookie.
Try it out and please let me know if this works...
Re: Dashticz - [BETA]Function - RGB-support
Posted: Tuesday 11 July 2017 22:23
by Onrust
Doesn't work here. I can select a color from the new selector, but nothing happens when I select Choose.
Posted: Tuesday 11 July 2017 22:26
by robgeerts
It should change when you click a color...
What kind of RGB-device do you have?
Posted: Tuesday 11 July 2017 22:27
by Onrust
Hue color/RGB lights.
Posted: Tuesday 11 July 2017 22:31
by robgeerts
Strange, I'm using it to.
Shall I try to fix it via Teamviewer?
PM me your ID and password...
Posted: Tuesday 11 July 2017 22:37
by Teunissm
tried it also over here but i can't change color as well
I use: Lighting Limitless/Applamp RGBW
by Onrust
PM sent
Posted: Tuesday 11 July 2017 22:53
by robgeerts
Could you try latest BETA @Teunissm?
Edit: 22:55 Small fix again
Posted: Tuesday 11 July 2017 23:02
by Teunissm
robgeerts wrote:Could you try latest BETA @Teunissm?
It still doesn't work.
With the first release de color indicator changed tot the color i choose but the lamp didn't react.
With the latest beta the color indicator don't even change??
Posted: Tuesday 11 July 2017 23:04
by robgeerts
Do you get any error in console?
The fix I just did is working for @Onrust...
Posted: Tuesday 11 July 2017 23:09
by Onrust
And I confirm it works for my other Hue's as well.
Posted: Tuesday 11 July 2017 23:12
by Teunissm
I don't see any errors in yhe console when switching the rgb light. I only have another rgb device as you use. I use Milight?
Posted: Tuesday 11 July 2017 23:14
by robgeerts
Ah that could be the problem. Maybe I can have a Teamviewer session with you tomorrow?
Posted: Tuesday 11 July 2017 23:17
by Teunissm
the i should instal teamviewer first
DONE
Update: So strange, everything works fine suddenly???
Thanx Rob
Posted: Wednesday 12 July 2017 0:06
by htilburgs
Hi Rob, I'm using Yeelight (Wifi), but trying to change the color the lamp turns to white.
Probably because Yeelight is not implemented.
Posted: Wednesday 12 July 2017 8:56
by robgeerts
I assume its working correctly in Domoticz? It could be this type of lamp needs another call... maybe we can debug it via Teamviewer tonight?
Posted: Thursday 13 July 2017 15:56
by EdwinK
robgeerts wrote:BETA
In latest beta it is possible to control your hue RGB-lamps..
How exactly do I try this
Posted: Thursday 13 July 2017 15:58
by robgeerts
Adding a hue lamp to your dashboard?
Posted: Thursday 13 July 2017 16:21
by EdwinK
ah.. I thought adding some sort of block thing or so
Posted: Thursday 13 July 2017 16:28
by EdwinK
- Screen Shot 2017-07-13 at 16.25.20.png (69.9 KiB) Viewed 4238 times
Although the lights do change to different colours, the icon only shows one colour for both devices
