add I2C BH1750 like tsl2561
jackslayter
Domoticz version: stable
Post by jackslayter »
hi , it's possible to add BH1750 i2c lux sensor to I2C hardware like TSL2561 ?
address
# Define some constants from the datasheet
DEVICE     = 0x23 # Default device I2C address
POWER_DOWN = 0x00 # No active state
POWER_ON   = 0x01 # Power on
RESET      = 0x07 # Reset data register value
# Start measurement at 4lx resolution. Time typically 16ms.
CONTINUOUS_LOW_RES_MODE = 0x13
# Start measurement at 1lx resolution. Time typically 120ms
CONTINUOUS_HIGH_RES_MODE_1 = 0x10
# Start measurement at 0.5lx resolution. Time typically 120ms
CONTINUOUS_HIGH_RES_MODE_2 = 0x11
# Device is automatically set to Power Down after measurement.
ONE_TIME_HIGH_RES_MODE_1 = 0x20
ONE_TIME_HIGH_RES_MODE_2 = 0x21
ONE_TIME_LOW_RES_MODE = 0x23
http://cpre.kmutnb.ac.th/esl/learning/b ... asheet.pdf
thank you
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
