Page 1 of 9
Dashticz - Module - Spotify (new version!)
Posted: Monday 10 July 2017 16:59
by robgeerts
Now can add a Spotify block.
Before you can use it, create an app on the spotify website:
https://developer.spotify.com/my-applic ... ons/create
Title: Dashticz
Description: whatever ;)
On the next page, copy "Client ID" to your CONFIG.js like:
config['spot_clientid'] = '1112f16564cf4f4dsd4cbe8b52c58a44';
At the same page, enter your dashticz-url in the Redirect URIs field, for example:'
http://192.168.1.3:8080/
DONT FORGET TO PUSH THE SAVE BUTTON!!
In CONFIG.js, add the block like:
columns[2] = {}
columns[2]['blocks'] = ['spotify']
columns[2]['width'] = 5;
Currently you can only change playlist, but more functions are coming!
Re: Dashticz - Module - Spotify
Posted: Monday 10 July 2017 17:52
by vgr2
Receiving: INVALID_CLIENT: Invalid redirect UR
Posted: Monday 10 July 2017 17:54
by Jonb
I’m back.
@Rob: Yes! Nice! Lets test tonight :mrgreen:
Posted: Monday 10 July 2017 17:55
by robgeerts
Did you enter the dashticz url into your spotify account in the app settings??
Posted: Monday 10 July 2017 17:58
by vgr2
Yes, as written...
Posted: Monday 10 July 2017 18:14
by robgeerts
Just to be sure, you didnt accidentally use the api key as I typed in the first post?
Posted: Monday 10 July 2017 18:20
by vgr2
Working with http://192.168.xxx.xx:8080/dashboard/ as redirect UR.
But after that i can only see 'Select playlist' button, nothing more. And yes I have a playlist.....
Posted: Monday 10 July 2017 20:10
by remb0
INVALID_CLIENT: Invalid redirect URI
tried also my domain (external url)
Posted: Monday 10 July 2017 20:34
by vgr2
did you save it on the developer spotify page? Without saving I had the same problem..
Posted: Monday 10 July 2017 21:00
by robgeerts
Vgr2: Dont you see a popup when you click on 'Select playlist'?
Posted: Monday 10 July 2017 21:10
by vgr2
I mean, empty playlist
Posted: Monday 10 July 2017 22:34
by EdwinK
remb0 wrote:INVALID_CLIENT: Invalid redirect URI
Same here. Triple checked to see if the API key was inserted correctly
Posted: Monday 10 July 2017 22:48
by robgeerts
Ok, I'll get back to the drawing table ;) will try to fix it tomorrow!
Posted: Tuesday 11 July 2017 9:37
by robgeerts
Well, I just tested it.
I tried to call the dashboard by localhost and 192.168.1.119 and both worked when entering the address to the spotify app page:
First time it didnt work till I found out I forgot to press the save button ;)
AND make sure you enter the Client ID in CONFIG.JS, and NOT (!) the Client Secret
Posted: Tuesday 11 July 2017 10:11
by vgr2
Hi Rob, whats about my empty playlist? Saw some same issues in google.
Posted: Tuesday 11 July 2017 10:22
by capman
INVALID_CLIENT: Invalid redirect URL
I have the same problem. Try this. Select the redirect url with your mouse (example: http://192.168.178.29/keuken/) Then click with your right mouse key on it and choose option "open link in new tab'. Now spotify ask you if you give permission to open this link. Click OK button. Solved !
Posted: Tuesday 11 July 2017 10:30
by robgeerts
vgr2 wrote:Hi Rob, whats about my empty playlist? Saw some same issues in google.
Good question, maybe we can solve this via Teamviewer? PM me..
Posted: Tuesday 11 July 2017 17:36
by robgeerts
Thanks to vgr2 I just pushed a fix in latest BETA!
Posted: Tuesday 11 July 2017 18:23
by EdwinK
All of a sudden it seems to work
Screen Shot 2017-07-11 at 21.24.45.png (37.62 KiB) Viewed 17978 times
Posted: Tuesday 11 July 2017 21:01
by vgr2
Rob, now I have to loging to Spotify parallel, otherwise it will not work.
