how to read Device values and write in Text file
Rezah
Post by Rezah »
hi there
i want to read all devices value and write them in a sensor.txt file.
i write a script for read from one device and write to text file and its work, but when i want read more than one device i get several error.
First code : read from one device
luxsensor = "ESP2_Lux"
if (devicechanged[luxsensor]) then
   print( " ####lux debug: "..devicechanged[luxsensor])
   file = io.open("sensor.txt", "w+")
    file:write("Sensors Status \n")
    file:write(luxsensor.." : "..devicechanged[luxsensor].."\n")
    file:close()
second code: read from more than one device
smokesensor = "Smoke_Sensor"
   file = io.open("sensorl.txt", "w+")
    file:write(smokesensor.." : "..devicechanged[smokesensor].."\n")
    file:close()
i get this:
2017-07-01 15:26:29.442 Error: EventSystem: in Lua LUX: [string "commandArray = {} ..."]:13: attempt to concatenate field '?' (a nil value)
please help me
tnx
freijn
Domoticz version: Stable
Re: how to read Device values and write in Text file
Post by freijn »
You do the first action on basis that the luxsensor value is changed.
In the second script you do the same only for the smokesensor there is nothing changed so I guess no info so no content which is a nil value.
Not sure home many sensors you are planning to log but why not make the same ( single sensor script ) for the smokesensor?
See below..
or......
Store all devicechanged values of sensors in variables, then have a separate script writing all variables in the file.
You could trigger the write file script by 1 of the deviced changed scripts.
Hope my story is not too smokey :-)
if (devicechanged[smokesensor]) then
print( " ####lux debug: "..devicechanged[smokesensor])
file:write(lsmokesensor.." : "..devicechanged[smokesensor].."\n")
file:close()
Rezah
Post by Rezah »
dear frejin
i tried to write same script for other devices, but i get errors.also i need to write all states of my devices to one file at same time.
lux is a parameter which changed every time and its good condition for me to read all device continuously.
but
i have try your second solution.
before that,can domoticz store values in userVariable automatically?
"Store all devicechanged values of sensors in variables, then have a separate script writing all variables in the file.
You could trigger the write file script by 1 of the deviced changed scripts."
Rezah
Post by Rezah »
i try frejin solution
Step 1:
write Script for all devices which i need them.
if device changed store the value in userVariables.
   commandArray['Variable:varLux']=devicechanged[luxsensor]
   commandArray['Variable:varSmoke']=devicechanged[smokesensor]
Step 2:
write a script for aggregation userVariables and write them in text File.
year 	= tonumber(os.date("%Y"));
month 	= tonumber(os.date("%m"));
day 	= tonumber(os.date("%d"));
hour 	= tonumber(os.date("%H"));
min 	= tonumber(os.date("%M"));
if (2==2) then
   -- Opens a file named sensor.txt(stored under Domoticz folder)
   -- in append mode
    --write to opened file
    file:write(year .. "-" .. month .. "-"..day.."   "..hour..":"..min.."\n")
    file:write(luxsensor.." : "..uservariables['varLux'].."\n")
    file:write(smokesensor.." : "..uservariables['varSmoke'].."\n")
    file:close() --closes the open file
freijn
Post by freijn »
And?
You got it working now?
Rezah
Post by Rezah »
yes,its work correctly
