Change hue brightness
dennusb
Post by dennusb »
I have a bunch of Hue lights, and i turn them on and off with Lua scripts (working fine). But i would also like to be able to set the brightness per light, but i cannot find how to do that...
Is there a simple way to post the intensity of the light from a LUA script?
commentator
Re: Change hue brightness
Post by commentator »
Yes
 os.execute('curl -s -H "Accept: application/json" -X PUT --data \'{"on":true, "sat":'..sat..', "bri":'..bri..',"hue":'..hue..'}\' http://<huebridgeip>/api/<seedocumentatioontogettheapikeyhere>/lights/<device number in hue bridge eg 4/state')
you can post these values:
sat
bri
hue
play a bit with them. Brightness is the parameter you're looking for
