Dashticz_V2 double check path Topic is solved
Eddiever
Domoticz version: 2022.1
Post by Eddiever »
I am getting this error messages:
please double check the path in HOST DOMOTICZ variable
I have searched this forum and learned that it could be a mistake in the CONFIG.js. But I don't seem to find it. Please help:
(normally spoken the dashboard is working). I masked some information.
var _LANGUAGE = 'nl_NL'; //or en_US
var _HOST_DOMOTICZ = 'http://192.168.1.200:8080'
var _APIKEY_WUNDERGROUND = '*******';
var _WEATHER_CITY = '*****';
var _WEATHER_COUNTRY = 'NL';
var _BACKGROUND_IMAGE = 'bg11.jpg';
var _USE_AUTO_POSITIONING = false;
var _USE_FAVORITES = false;
var _HIDE_SECONDS_IN_CLOCK = false;
var _IDXmoonpicture = 1; //index of the uservariabele MoonPicture
var _STANDBY_AFTER_MINUTES = 60
// var _DASHTICZ_REFRESH = 0
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/hoogeveen/1813744/'}
buttons.moon= {width:12, isimage:true, refreshimage:60000, image: 'moon'}
//example station id: station-eindhoven
var publictransport = {}
publictransport.ovinfo= { station: 'station-hoogeveen', title:'Trein Hoogeveen', show_lastupdate:true, provider: '9292', icon: 'train', results: 5 };
publictransport.ovinfobus= { station: 'station-hoogeveen', title:'Bus', show_lastupdate:true, provider: '9292-bus', icon: 'bus', results: 5 };
publictransport.ovinfotrain= { station: 'station-hoogeveen', title:'Trein', show_lastupdate:true, provider: '9292-train', icon: 'train', results: 5 };
var calendars = {}
calendars.business = { maxitems: 5, url: 'https://calendar.google.com/calendar/', icalurl: 'https://calendar.google.com/calendar/' }
calendars.private = { maxitems: 5, icalurl: '**********' }
var blocks = {}
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Weer';
blocks[3] = {}
blocks[3]['title'] = 'lamp woonkamer';
blocks[4] = {}
blocks[4]['title'] = 'lamp slaapkamer';
blocks[12] = {}
blocks[12]['icon'] = 'fa-tv';
blocks[12]['title'] = 'TV boven';
blocks[16] = {}
blocks[16]['icon'] = 'fa-tv';
blocks[16]['title'] = 'TV beneden';
blocks[45] = {}
blocks[45]['icon'] = 'fa-moon-o';
blocks[45]['title'] = 'Maan';
blocks[45]['switch'] = true;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['graph_23',3,4,5,16,12,13,14,15]
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_2','weather',6,9,7,8,23,publictransport.ovinfotrain, calendars.private]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,buttons.moon]
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
htilburgs
Re: Dashticz_V2 double check path
Post by htilburgs »
I've loaded your CONFIG.js (change the var _HOST_DOMOTICZ = 'http://192.168.1.200:8080' to my URL) and I have a dashboard loading, without errors.
Can you check your variable and look if you have the correct IP and PORT NUMBER?
On further thing, it works, but normaly there's a colon (;) after each variable.
Can you put a colon behind the var _HOST_DOMOTICZ = 'http://192.168.1.200:8080';
ps.
There is a subforum especialy for Dashticz v2 - http://www.domoticz.com/forum/viewforum.php?f=67
Hardware:
Eddiever
Post by Eddiever »
htilburgs, thanks a lot. Looks like the missing colon did the trick! And also thanks for the subforum tip!
(learning all the time)
joostnl
Post by joostnl »
I also have this double check error.
It seems dashticz freezes for few sec and then i get this error.
Above fix didn't help could it be something else?
var config = {}
config['domoticz_ip'] = 'http://192.168.1.13:2449';
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['hide_topbar'] = 1;
config['last_update'] = 0;
config['wu_api'] = 'secret';
config['wu_city'] = 'pws:INOORDHO146';
config['wu_name'] = 'secret';
config['no_rgb'] = 1;
config['spot_clientid'] = 'secret';
config['longfonds_zipcode'] = 'secret';
config['longfonds_housenumber'] = 'secret';
var _HOST_DOMOTICZ = 'http://192.168.1.13:2449';
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
var coins = {}
coins.bitcoin = { key:'bitcoin', currency: 'EUR', layout:'vertical',width:4 }
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg_morning.jpg';
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Light';
blocks['blocktitle_2']['title'] = 'Temperature'
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Power';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Plants';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Multimedia';
blocks[4] = {single_block: true};
blocks[3] = {single_block: true};
blocks[1046] = {single_block: true};
blocks[460] = {single_block: true};
columns[1] = {}
columns[1]['blocks'] = [418,909,446,870,137,26,'8_1','8_2','8_3',9,832,'961_1',792,794,793,'spotify']
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = [,6,4,3,1046,460,103,102,coins.bitcoin,'longfonds',159,163,173,12,16,14,'graph_8']
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','weather',buttons.buienradar,'traffic']
columns[3]['width'] = 3;
HansieNL
Post by HansieNL »
Can you remove the comma before the 6 and see what happens?
Blah blah blah
joostnl
Post by joostnl »
Thanks for your suggestion only it didn't work.
I removed more unused title but the problem is still there.
Really iritating from the beginning on Dashticz it freezes sometimes and i get this cannot reach domoticz error.
Is your buienradar and weather forecast animation without lag on an android tablet? (i'm using kiosk browser pro)
Could this give conflicts?
and
Any suggestion?
var config = {}
config['wu_city'] = 'secret';
var buttons = {}
var coins = {}
var screens = {}
screens[1] = {}
columns[1] = {}
columns[2] = {}
columns[2]['blocks'] = [6,4,3,1046,460,103,102,coins.bitcoin,'longfonds',159,163,173,12,16,1065,'graph_8']
columns[3] = {}
HansieNL
Post by HansieNL »
I think some variabels are still missing: var blocks = {} , var columns = {}
If autopositioning=0 you have to add all blocks you wanna use to config.js.
You can check the wiki how to use blocks, columns and screens.
Blah blah blah
