timeofday has same values - everytime
Domoberry
Domoticz version: 2026.2
Post by Domoberry »
Hi Forum,
Probably a stupid question, but since I cannot figure it out...
I'm using:
print("Sunset in minutes = " .. timeofday['SunsetInMinutes'])
and this always returns:
2017-06-20 21:56:07.977 LUA: Sunset in minutes = 1317
regardless of the time of the day; it is always 1317
I printed the table contents using some table-print function, which always gives:
SunriseInMinutes= 321,
SunsetInMinutes= 1317,
Daytime= "true",
Nighttime= "false",
Also checked the time on my RPI:
pi@raspberrypi:~ $ date
Tue Jun 20 22:02:33 CEST 2017
which seems to be OK
As well as the time in Domoticz:
2017-06-20 22:03:23 ☀▲05:21 ▼21:57
There must be something obvious I overlooked. Any tip for me?
jvdz
Domoticz version: 4.107
Re: timeofday has same values - everytime
Post by jvdz »
Domoberry wrote:Hi Forum,
Why are you expecting the time the SunSets to change during the day? ;)
What exactly are you looking for here or what do you want to test for?
Jos
Domoberry
Post by Domoberry »
I new I missed something...
I wrongly assumed that 'TimeOfDay['SunsetInMinutes'] would be a nifty little table telling me when to expect for example sunset, e.g. 'sunset will be in xxx minutes' :oops:
1321 minutes equals to 21 hours and 57 which... is when... the sun sets. My bad.
(what I was trying to do was to find a simple way to do something like 'the light should be off between xx:xx and yy:yy and behave as per the rest of the script on other times. So started looking for the various time-related functions and thought I give the hint in the lua Domoticz template a try)
To avoid me misusing the forum again - and make this post still somewhat useful - which 'reference manual' is the best for the Domoticz-Lua newbee?
jvdz
Post by jvdz »
So you still can have lights behave taking that value into account and simply calculate with the current time.
I use something like this in a script to act on times around sunset:
timenow = os.date("*t")
minutesnow = timenow.min + timenow.hour * 60
if minutesnow >= timeofday['SunsetInMinutes'] + 10
and minutesnow < timeofday['SunsetInMinutes'] then
	-- do something between sunset and 10 minutes after
Jos
Domoberry
Post by Domoberry »
Hi Jos,
Thanks for the suggestion, I like the use of timenow = os.date("*t") and the resulting table! Makes things easier!
Got the time based thingy to work and... gathered new knowledge on the way.
Thanks, W.ytze
