Problem with Data push (HTTP) to InfluxDB - Wrong value sent (Humidity from DS2438)
frstep
Post by frstep »
Not sure where this question goes: I don't think it is a 1-wire issue (DS2438) as Domoticz correctly finds the device and reports it (currently 63%). This has been working fine for a month. But it appears the value being sent to InfluxDB is wrong:
2017-06-14 14:03:42.878 (1-wire sensor circuit) Humidity (Humidity)
2017-06-14 14:03:42.890 HttpLink: sending global variable 30 with value: 3
2017-06-14 14:03:42.919 HttpLink: response
2017-06-14 14:03:42.923 HttpLink: sending global variable with value: Wet
2017-06-14 14:03:42.932 HttpLink: response
2017-06-14 14:03:42.935 HttpLink: sending global variable 30 with value: Wet
2017-06-14 14:03:42.944 HttpLink: response
I can't work out where the "3" is coming from.
All my temperature values are working fine. The http post is to http://127.0.0.1:8086/write?db=domoticz ... ecision=ms with data device_%V value=%v %t3
Any ideas?
Thanks,
Fraser.
