I connected a DS2438 hobby board barometer. It is recognised by Domoticz 3.7679 as "solar radiation" and not barometer.
Address is 26.775CB5000000
109 1-Wire 43 1 Solar Radiation General Solar Radiation 1000.0 Watt/m2 - - Ajouter un dispositifRenommer le dispositif Log 2017-06-13 21:16:55
108 1-Wire 775C 92 Temperature Temp LaCrosse TX3 31.8 C - - Ajouter un dispositifRenommer le dispositif Log 2017-06-13 21:16:55
-Temperature measurement is correct. but I wonder why the domoticz "ID" is always truncated to 775C and not the complete 1-wire address ?
-Solar radiation is crazy: it is supposed to be pressure
1WireByOWFS.cpp:
float C1WireByOWFS::GetPressure(const _t1WireDevice& device) const
std::string realFilename = device.filename + nameHelper(device.filename, device.family); // for family 26 (DS2438) + pressure + HobbyBoards
std::string readValue=readRawData(std::string(realFilename+"/pressure"));
if (readValue.empty())
return -1000.0;
return static_cast<float>(atof(readValue.c_str()));My full path (including master hub) is /mnt/1wire/1F.313104000000/main/26.775CB5000000/B1-R1-A/pressure
Any idea ?
Thank you
