PiHole Script
PiHole Script
I created a script to add output of the PiHole api to Domoticz
Link to the script on the wiki: https://www.domoticz.com/wiki/Display_o ... PiHole_api
Link to the website of the PiHole project: https://pi-hole.net
Re: PiHole Script
Nice interface.
The output is already JSON, so a little more readable solution might be:
INPUT=`curl -s 'http://192.168.2.159/admin/api.php'`
DOMAINSBLOCKED=`echo $INPUT | jq -r '.domains_being_blocked'`
or even better switch to lua.
In the crontab full path should be used, so /home/pi/......
Nice interface.
- Domoticz version: BETA
Re: PiHole Script
mmm
My pihole fucku.. my xu4....
Something with rights...
My hdd is going straid to hell.... from the time i did install pihole....
Now i try to get my space back...
Run pihole on a old rpi... works great
Re: PiHole Script
Nice script, thanks a lot for sharing!
Verstuurd vanaf mijn LG-H870 met Tapatalk
- EdwinK
Re: PiHole Script
Thanks, too bad Pi-Hole was making my system unresponsive.
Re: PiHole Script
pi-hole did the same to my raspberry. where I run domoticz.EdKo66 wrote:Thanks, too bad Pi-Hole was making my system unresponsive.
I now have a docker version on my synology, that runs great, stable and on low resources.
Re: PiHole Script
I keep PiHole, Domoticz and Squeezebox (Logitech Media Server) on one Pi2 and it works just fine. Though my Domoticz only has a few switches so far.
- Domoticz version: 3.8807
Re: PiHole Script
@TapNL thanks for introducing me to Pi-Hole - really useful tool.
I like to keep things inside Domoticz, so I have created a Lua script instead and used Customer Sensors, so Domoticz will create graphs similar to the Pi-Hole dashboard display.
Lua is quite good for this sort of task as the combination of a json library and tables, means that the real work is done in 4 lines:
Needless to say the whole code is a bit longer:
And you need to have socket and json libraries installed as described here for a Raspberry Pi - http://www.domoticz.com/wiki/Upload_ene ... et_library and http://dkolf.de/src/dkjson-lua.fsl/home.
for JsonField,DeviceName in pairs(PiHoleFields) do
i=i+1
commandArray[i] = {['UpdateDevice'] = otherdevices_idx[DeviceName] .. "|0|" .. decoded_response[JsonField]}
--~/domoticz/scripts/lua/script_time_pihole.lua
-- Query pi-hole and make data available in Domoticz
--Uservariables
PiHoleIP="192.168.89.251" -- ip of your Pi-Hole machine
-- PiHoleFields is a table of the json keys and Domoticz device names, which is used to retrieve the data
-- from the json returned by Pi-Hole and upload it to the named appropriate Domoticz device.
-- Basically in PiHoleFields table - json_field = "Domoticz Device Name"
-- Before installing the script create 7 Domoticz dummy device virtual sensors, all customer sensors,
-- except ads_percentage_today which is percentage custom sensor.
PiHoleFields={domains_being_blocked="Domains Blocked",dns_queries_today="DNS Queries",ads_blocked_today="Ads Blocked",ads_percentage_today="Ads Percent",unique_domains="Unique Domains",queries_forwarded="Queries Forwarded",queries_cached="Queries Cached"}
-- Set how often the date is checked by:
minutesbetween = 5
time = os.date("*t")
-- Check every hour
--if time.min == ReportMinute then
--if time.hour == ReportHour and time.min == ReportMinute then
if (((time.min)%minutesbetween) == 0) then
-- Only load libaries now
io = require('io')
http = require('socket.http')
https = require "ssl.https";
JSON = require('JSON')
-- Retreive Pi-Hole Information
PiHoleURL = "http://"..PiHoleIP.."/admin/api.php"
jresponse, status = http.request(PiHoleURL)
decoded_response = JSON:decode(jresponse)
i = 0
i=i+1
--LUA default
Re: PiHole Script
@simonrg: Thx for lua script - also a possibility, not a LUA jedi - not even a bash jedi.
Nice to see, that it is interesting for people.
Re: PiHole Script
The script is running, however nothing changes in Domoticz:
My script is:
This is the output of the pihole api call
What is going wrong?
Just did an update to the latest pihole version 3.1, maybe that has some effect?
pi@raspberrypi:~ $ sudo bash ~/Scripts/pihole.sh
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 204 0 204 0 0 5020 0 --:--:-- --:--:-- --:--:-- 5100
: invalid number/pihole.sh: line 21: printf: 110311
: invalid number/pihole.sh: line 22: printf: 29201
: invalid number/pihole.sh: line 23: printf: 6832
: invalid number/pihole.sh: line 24: printf: 1563
: invalid number/pihole.sh: line 25: printf: 14593
#!/bin/bash
# Settings
PIHOLE_IP="192.168.178.97" # PiHole IP
DOMO_IP="192.168.xx.xx" # Domoticz IP
DOMO_PORT="xx" # Domo port
DOMAINSBLOCKED_IDX='1278'
DNSQUERIESTODAY_IDX='1279'
ADSBLOCKEDTODAY_IDX='1280'
ADSPERCENTTODAY_IDX='1283'
UNIQUEDOMAINS_IDX='1281'
QUERIESFORWARDED_IDX='1282'
# Get data from Pi_Hole API
INPUT=$(curl "http://$PIHOLE_IP/admin/api.php")
DOMAINSBLOCKED=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $2}')
DNSQUERIESTODAY=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $4}')
ADSBLOCKEDTODAY=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $6}')
ADSPERCENTTODAY=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $8}')
UNIQUEDOMAINS=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $10}')
QUERIESFORWARDED=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $12}')
#Make data more readable
DOMAINSBLOCKED=$(printf "%'d" "$DOMAINSBLOCKED")
DNSQUERIESTODAY=$(printf "%'d" "$DNSQUERIESTODAY")
ADSBLOCKEDTODAY=$(printf "%'d" "$ADSBLOCKEDTODAY")
UNIQUEDOMAINS=$(printf "%'d" "$UNIQUEDOMAINS")
QUERIESFORWARDED=$(printf "%'d" "$QUERIESFORWARDED")
# Load data in domoticz
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$DOMAINSBLOCKED_IDX&nvalue=0&svalue=$DOMAINSBLOCKED"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$DNSQUERIESTODAY_IDX&nvalue=0&svalue=$DNSQUERIESTODAY"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$ADSBLOCKEDTODAY_IDX&nvalue=0&svalue=$ADSBLOCKEDTODAY"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$ADSPERCENTTODAY_IDX&nvalue=0&svalue=$ADSPERCENTTODAY"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$UNIQUEDOMAINS_IDX&nvalue=0&svalue=$UNIQUEDOMAINS"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$QUERIESFORWARDED_IDX&nvalue=0&svalue=$QUERIESFORWARDED"
{"domains_being_blocked":110311,"dns_queries_today":29339,"ads_blocked_today":6871,"ads_percentage_today":23.41934,"unique_domains":1564,"queries_forwarded":14673,"queries_cached":7795,"unique_clients":5}
Re: PiHole Script
Did you find what your problem was?jjnj wrote:What is going wrong?
There appears to be nothing wrong with the script it runs fine on my machine.
However, I would suggest removing the printf statements and changing your Domoticz devices to Custom Sensors, so that Domoticz will do the formatting for you.
So script would be simply:
#!/bin/bash
# Settings
PIHOLE_IP="192.168.89.251" # PiHole IP
#DOMO_IP="192.168.xx.xx" # Domoticz IP
#DOMO_PORT="xx" # Domo port
INPUT='{"domains_being_blocked":110311,"dns_queries_today":29339,"ads_blocked_today":6871,"ads_percentage_today":23.41934,"unique_domains":1564,"queries_forwarded":14673,"queries_cached":7795,"unique_clients":5}'
Re: PiHole Script
Thanks, i will try when back homesimonrg wrote:Did you find what your problem was?jjnj wrote:What is going wrong?
So script would be simply:Code: Select all
#!/bin/bash # Settings PIHOLE_IP="192.168.89.251" # PiHole IP #DOMO_IP="192.168.xx.xx" # Domoticz IP #DOMO_PORT="xx" # Domo port DOMAINSBLOCKED_IDX='1278' DNSQUERIESTODAY_IDX='1279' ADSBLOCKEDTODAY_IDX='1280' ADSPERCENTTODAY_IDX='1283' UNIQUEDOMAINS_IDX='1281' QUERIESFORWARDED_IDX='1282' # Get data from Pi_Hole API INPUT=$(curl "http://$PIHOLE_IP/admin/api.php") INPUT='{"domains_being_blocked":110311,"dns_queries_today":29339,"ads_blocked_today":6871,"ads_percentage_today":23.41934,"unique_domains":1564,"queries_forwarded":14673,"queries_cached":7795,"unique_clients":5}' DOMAINSBLOCKED=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $2}') DNSQUERIESTODAY=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $4}') ADSBLOCKEDTODAY=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $6}') ADSPERCENTTODAY=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $8}') UNIQUEDOMAINS=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $10}') QUERIESFORWARDED=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $12}') #Make data more readable DOMAINSBLOCKED=$(printf "%'d" "$DOMAINSBLOCKED") DNSQUERIESTODAY=$(printf "%'d" "$DNSQUERIESTODAY") ADSBLOCKEDTODAY=$(printf "%'d" "$ADSBLOCKEDTODAY") UNIQUEDOMAINS=$(printf "%'d" "$UNIQUEDOMAINS") QUERIESFORWARDED=$(printf "%'d" "$QUERIESFORWARDED") # Load data in domoticz curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$DOMAINSBLOCKED_IDX&nvalue=0&svalue=$DOMAINSBLOCKED" curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$DNSQUERIESTODAY_IDX&nvalue=0&svalue=$DNSQUERIESTODAY" curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$ADSBLOCKEDTODAY_IDX&nvalue=0&svalue=$ADSBLOCKEDTODAY" curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$ADSPERCENTTODAY_IDX&nvalue=0&svalue=$ADSPERCENTTODAY" curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$UNIQUEDOMAINS_IDX&nvalue=0&svalue=$UNIQUEDOMAINS" curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$QUERIESFORWARDED_IDX&nvalue=0&svalue=$QUERIESFORWARDED"
- Domoticz version: 2021.1
Re: PiHole Script
I updated the script so it works with the latest Pi-Hole version (incl API Token), I thaught maybe somebody else needs it.
Below the script with some example data (fake API token).
I added the script into my synology, so it can run every 5min.
#!/bin/bash
# Settings
PIHOLE_IP="192.168.1.xx" # PiHole IP
DOMO_IP="192.168.1.xx" # Domoticz IP
DOMO_PORT="80xx" # Domo port
API_TOKEN="e0922ed316ff63fa00304e6aa8547d43e2d1ff55ab7a07caa2662f34b6222f0e" # PiHole API Token, found here: pihole->settings->API->show token
DOMAINSBLOCKED_IDX='1444'
DNSQUERIESTODAY_IDX='1445'
ADSBLOCKEDTODAY_IDX='1446'
ADSPERCENTTODAY_IDX='1447'
UNIQUEDOMAINS_IDX='1449'
QUERIESFORWARDED_IDX='1450'
QUERIESCACHED_IDX='1451'
CLIENTSEVERSEEN_IDX='1452'
UNIQUECLIENTS_IDX='1453'
INPUT=$(curl "http://$PIHOLE_IP/admin/api.php?summaryRaw&auth=$API_TOKEN")
domains_being_blocked=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $2}')
dns_queries_today=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $4}')
ads_blocked_today=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $6}')
ads_percentage_today=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $8}')
unique_domains=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $10}')
queries_forwarded=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $12}')
queries_cached=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $14}')
clients_ever_seen=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $16}')
unique_clients=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $18}')
dns_queries_all_types=$(echo "$INPUT" | awk -v FS="(:|,)" '{print $20}')
domains_being_blocked=$(printf "%'d" "$domains_being_blocked")
dns_queries_today=$(printf "%'d" "$dns_queries_today")
ads_blocked_today=$(printf "%'d" "$ads_blocked_today")
ads_percentage_today$(printf "%'d" "$ads_percentage_today")
unique_domains=$(printf "%'d" "$unique_domains")
queries_forwarded=$(printf "%'d" "$queries_forwarded")
queries_cached=$(printf "%'d" "$queries_cached")
clients_ever_seen=$(printf "%'d" "$clients_ever_seen")
unique_clients=$(printf "%'d" "$unique_clients")
dns_queries_all_types=$(printf "%'d" "$dns_queries_all_types")
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$DOMAINSBLOCKED_IDX&nvalue=0&svalue=$domains_being_blocked"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$DNSQUERIESTODAY_IDX&nvalue=0&svalue=$dns_queries_today"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$ADSBLOCKEDTODAY_IDX&nvalue=0&svalue=$ads_blocked_today"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$ADSPERCENTTODAY_IDX&nvalue=0&svalue=$ads_percentage_today"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$UNIQUEDOMAINS_IDX&nvalue=0&svalue=$unique_domains"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$QUERIESFORWARDED_IDX&nvalue=0&svalue=$queries_forwarded"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$QUERIESCACHED_IDX&nvalue=0&svalue=$queries_cached"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$CLIENTSEVERSEEN_IDX&nvalue=0&svalue=$clients_ever_seen"
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$UNIQUECLIENTS_IDX&nvalue=0&svalue=$unique_clients"
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
- sincze
- Domoticz version: 2024.4
Re: PiHole Script
Tnx Chris, just noticed your post on the Pi-Hole plugin not working anymore.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Re: PiHole Script
Yeah, I let it wait for a while hoping some-one would fix it, not sure bc it's been a while. Then I found this post, and worked on that to get it working!
- sincze
Re: PiHole Script
Need to check but it could be this Plugin faces the same issues I experienced before with a different version of Domoticz with the onConnect issue as the URL used is the same as you are using..
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Re: PiHole Script
Thanks for this.
The wiki is still dated 2017 with the old script. Chris12's script above works nicely, thanks.
I thought I would log in and change it but my forum login doesn't work for the wiki and I can't see anywhere to create a new user.
Anyone know what to do?
Running Domoticz and Dashticz beta on Raspberry Pi OS 32 bit - has anyone had success with 64 bit?
Desktop access from Ubuntu Linux
