how factory reset nodemcu after load espeasy for other uses? please an easy way :)
Posted: Tuesday 13 June 2017 12:40
by reza
hi friend
i load a espeasy on my nodemcu and now i want other use . but can not. i search and found some way for "flash" and factory reset but i can not understand for my weak in english :( can i help me for flash nodemcu with a easy way ? thank you.
Re: how factory reset nodemcu after load espeasy for other uses? please an easy way :)
Posted: Tuesday 13 June 2017 12:59
by SweetPants
All depends on what blocks are used in the ESP en type of module by NodeMCU. I'm not sure if you will get an answer on this forum.
Posted: Tuesday 13 June 2017 14:14
by reza
SweetPants wrote:All depends on what blocks are used in the ESP en type of module by NodeMCU. I'm not sure if you will get an answer on this forum.
i am using nodemcu for first time , and i dont know how use this. i do all step in espeasy wiki .this is a nodemcu ch340G v1. now can you help how i can remove espeasy on nodemcu? thank you
Posted: Tuesday 13 June 2017 20:23
by SweetPants
reza wrote:i am using nodemcu for first time , and i dont know how use this. i do all step in espeasy wiki .this is a nodemcu ch340G v1. now can you help how i can remove espeasy on nodemcu? thank you
Bassically re-flash it with something else you want on the module.
Posted: Wednesday 14 June 2017 9:08
by reza
thank you
