i load a espeasy on my nodemcu and now i want other use . but can not. i search and found some way for "flash" and factory reset but i can not understand for my weak in english
how factory reset nodemcu after load espeasy for other uses? please an easy way :)
reza
- Domoticz version: 2024.4
hi friend
can i help me for flash nodemcu with a easy way ? thank you.
SweetPants
Re: how factory reset nodemcu after load espeasy for other uses? please an easy way :)
All depends on what blocks are used in the ESP en type of module by NodeMCU. I'm not sure if you will get an answer on this forum.
reza
i am using nodemcu for first time , and i dont know how use this. i do all step in espeasy wiki .this is a nodemcu ch340G v1. now can you help how i can remove espeasy on nodemcu? thank youSweetPants wrote:All depends on what blocks are used in the ESP en type of module by NodeMCU. I'm not sure if you will get an answer on this forum.
SweetPants
Bassically re-flash it with something else you want on the module.reza wrote:i am using nodemcu for first time , and i dont know how use this. i do all step in espeasy wiki .this is a nodemcu ch340G v1. now can you help how i can remove espeasy on nodemcu? thank you
reza
thank youSweetPants wrote:Bassically re-flash it with something else you want on the module.reza wrote:i am using nodemcu for first time , and i dont know how use this. i do all step in espeasy wiki .this is a nodemcu ch340G v1. now can you help how i can remove espeasy on nodemcu? thank you
