qwerk wrote:qwerk wrote:so far, i have seen no more problems.
I take that back.
after running 44 hours, it is getting real slow. especially z-wave.
I thought I noticed a few slow responds the past two days, but the next action was normal, so I didn't blame the domotica.
But now again after a trigger it takes over two minutes for the z-wave devices to respond.
Running domoticz 3.7602 , on a raspberry B
I switched to dzvents for my scripts a few weeks back, and was very pleased with the new overall performance.
I will give more info when I have it.
I have a clip from my log.
2017-06-03 15:48:19.972 2017-06-03 15:48:19.972 LUA: Handling events for: "PIR Badkamer", value: "On"
2017-06-03 15:48:19.973 2017-06-03 15:48:19.973 LUA: >>> Handler: PIR-badkamer
2017-06-03 15:48:19.973 2017-06-03 15:48:19.973 LUA: >>> Device: "PIR Badkamer" Index: 1358
2017-06-03 15:48:19.974 2017-06-03 15:48:19.974 LUA: [2] = Lamp badkamer spiegel: Set Level 60
2017-06-03 15:48:19.974 2017-06-03 15:48:19.974 LUA: [3] = Lamp badkamer plafond: Set Level 60
2017-06-03 15:48:19.501 (Razberry) Light/Switch (PIR Badkamer)
2017-06-03 15:48:38.995 2017-06-03 15:48:38.995 LUA: Handling events for: "PIR Badkamer", value: "Off"
2017-06-03 15:48:38.996 2017-06-03 15:48:38.996 LUA: >>> Handler: PIR-badkamer
2017-06-03 15:48:38.996 2017-06-03 15:48:38.996 LUA: >>> Device: "PIR Badkamer" Index: 1358
2017-06-03 15:48:38.515 (Razberry) Light/Switch (PIR Badkamer)
2017-06-03 15:48:40.039 2017-06-03 15:48:40.039 LUA: Handling events for: "Lamp badkamer spiegel", value: "Set Level: 60 %"
2017-06-03 15:48:40.040 2017-06-03 15:48:40.040 LUA: >>> Handler: Lamp-badkamer
2017-06-03 15:48:40.040 2017-06-03 15:48:40.040 LUA: >>> Device: "Lamp badkamer spiegel" Index: 1411
2017-06-03 15:48:39.038 (Razberry) Light/Switch (Lamp badkamer spiegel)
2017-06-03 15:48:49.543 2017-06-03 15:48:49.543 LUA: Handling events for: "Lamp badkamer plafond", value: "Set Level: 60 %"
2017-06-03 15:48:49.544 2017-06-03 15:48:49.544 LUA: >>> Handler: Lamp-badkamer
2017-06-03 15:48:49.544 2017-06-03 15:48:49.544 LUA: >>> Device: "Lamp badkamer plafond" Index: 1474
2017-06-03 15:48:48.487 (Razberry) Light/Switch (Lamp badkamer plafond)
a PIR detected movement at 15:48:19
according to dzvents lua logging it activated two lights the same second.
razberry got the assigment 20 and 30 seconds later.
I was at the bathroom and indeed there was a huge delay.
edit: did exact the same thing, twice, had nothing changed in domoticz, scripting, no restarting or rebooting, and now it all worked instantly.
