python plugin: sunset/sunrise times
elgringo
Domoticz version: Left
Post by elgringo »
Is it possible to get sunrise/sunset times from Domoticz within a python plugin?
Or the user variables?
elgringo
Re: python plugin: sunset/sunrise times
Post by elgringo »
I hope there are some better option to implment it by my own. There are examples how to do it:
http://thorpesoftware.com/calculating-s ... nd-sunset/
https://www.raspberrypi.org/forums/view ... 2&t=114745
It's like reinventing hte wheel :shock:
Hesmink
Post by Hesmink »
elgringo
Post by elgringo »
Yes its possible, I thought of it. But is doesn't make sense to call the domoticz API from a plugin.
I assume it is available within the plugin context since all settings also can be retrieved.
sincze
Domoticz version: 2024.4
Post by sincze »
elgringo wrote: Wednesday 31 May 2017 11:45
Did anyone find a solution for this so to obtain sunrise and sunset from within a plugin ?
I found something like this.
cmd = '/json.htm?type=command&param=getSunRiseSet'
        dJson = self.request(self.url(cmd))
        Domoticz.Debug("result:" + str(dJson))
And I must agree, it feels a bit strange to need to go external to obtain these values ;-) but then again if that is as designed.... it is what it is..
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
