Timers not always working.
Posted: Sunday 28 May 2017 10:39
by SVLmarc
Hi there,
I'm new here. Just started Domoticz on Pi3 with RFXtrx433E. Yesterday I started a simpel test. Lamps on at 20 min before sunset and turn off at the fixed time 23:30.
Lamp go on on time but won't go off. After experimenting with the fixed times it looks like it's not working most of the times.
Anyone else with this problem?
Manuall on/off works all the time.
Hope to hear from you.
Re: Timers not always working.
Posted: Sunday 28 May 2017 10:41
by freijn
Have a look in the logfile, do you see the "off" command there?
Posted: Sunday 28 May 2017 10:49
by SVLmarc
In the log file it sometimes says off while it schould be on at that time.
Posted: Sunday 28 May 2017 10:52
by SVLmarc
Seems that the problem only occurs with the 'on time' function.
Posted: Sunday 28 May 2017 11:38
by SVLmarc
That could be an issue, but if I turn them on and off manually with Domoticz they always turn on and off. They always respond at the first klick. Also with the original KAKU remote.
Posted: Sunday 28 May 2017 15:38
by Amsterdam020
After a restart of my pi the timer's wont work any more is my experience.
Did you also restart?
Posted: Sunday 28 May 2017 21:58
by assenzuid
My timers are also not working anymore. (Running latest beta)
I have a few configured and all to switch on after sunset (they all failed).
All running with Z-Wave devices.
- Capture.JPG (93.85 KiB) Viewed 4430 times
Posted: Monday 29 May 2017 21:41
by assenzuid
After the last update my timers are working again
Posted: Sunday 07 January 2018 19:49
by brydling
I am running the latest beta (3.8799) on Windows with two Z-Wave light switches and I have the same problem. On Time does not work. Haven't tried the sunrise and sunset timers.
Posted: Sunday 07 January 2018 20:26
by jvdz
brydling wrote: Sunday 07 January 2018 19:49
Forum search is your friend as this is extensively discuss and fix is awaiting to be merged and new Beta to be build:
http://www.domoticz.com/forum/viewtopic.php?f=6&t=21013
Jos
Posted: Sunday 07 January 2018 21:23
by brydling
Thank you! I searched but not good enough it seems
