RFLink devices don't appear in the device list - beta version
THEND
Post by THEND »
Hardware RaspberryPi Zero
RFLink Gateway USB is installed
Version: 3.7479
I follow the wiki:
Q: My devices don't appear in the device list.
A: Make sure you have added hardware, have it enabled and tick "Accept new hardware devices" in Setup|Application settings.
Hello, I have problem with RFLink devices. I have enabled and tick "Accept new hardware devices" in Setup|Application settings but my devices don't appear in the device list. I noticed that the problem is on the beta version Domoticz.
If I manually add devices, a message appears but no devices in the list.
Stuntteam
Re: RFLink devices don't appear in the device list - beta version
Post by Stuntteam »
You probably used an incorrect command structure
THEND
Post by THEND »
Stuntteam wrote:You probably used an incorrect command structure
The command structure is correct because it turns on and off the sockets 433MHz but devices don't appear in the device list. If used an incorrect command structure I get the appropriate message.
Correct command:
2017-05-25 21:49:21.346 User: initiated a RFLink Device Create command: 10;Maclean;3fa5;03;ON;
For example incorrect command:
2017-05-25 21:50:17.118 User: initiated a RFLink Device Create command: 10;Maclean;3fa5;03;ON;111
2017-05-25 21:50:17.197 Error: RFLink: Error/Unknown command received!...
Stuntteam
Post by Stuntteam »
You need to enter the commands as displayed by RFLink when it receives a signal from the remote..
thus something like:
20;18;Maclean;ID=3fa5;SWITCH=03;CMD=ON;
stingone
Post by stingone »
Same Issue here for Ansluta... but no replys so far
the command is 20;4C;ANSLUTA;ID=d3d2;SWITCH=0;CMD=ON;
no device and gives me unhandled switch type.... in the log.
