G.R. GR105n Auto Valve switch does not work Topic is solved
lonwan
Post by lonwan »
Hello! I have the latest beta domoticz(3.7450) on the Raspberry Pi 3 and the expansion board of the razberry. I have a G.R. GR105n Auto Valve. But a switch is created that does not send commands! It only shows the current status of the valve, only the button on the tap itself works and through the control panel OpenZWave. Again, through the OpenZWave control panel, the commands are successfully sent and the valve opens and closes. But in the domoticz is no. Maybe someone faced such a problem? What should I do?
Valve photo:
p.s. Sorry for my English
berny
Re: G.R. GR105n Auto Valve switch does not work
Post by berny »
this was the solution for the Flow Stop (009501).....
by PjotrE » Sunday 19 February 2017 21:34
https://www.domoticz.com/forum/viewtopi ... ow#p120479
lonwan
Post by lonwan »
berny wrote:this was the solution for the Flow Stop (009501).....
viewtopic.php?f=24&t=15435&p=120479&hil ... ow#p120479
Thank you very much! You really helped! I just replaced the configuration file of my valve with a new one and it all worked! The switch in the domoticz opens and closes the valve!
Procedure:
sudo service domoticz stop
Next, I went through WinSCP in the folder
/home/pi/domoticz/Config/gr
and replaced the file
gr105n.xml
В файле конфигурации
 /home/pi/domoticz/Config/zwcfg_youhomeid.xml
привести ноду крана к виду:
(Node id="8" - тут номер вашей ноды)
(У меня были лишние CommandClass id, я их удалил)
    <Node id="8" name="" location="" basic="4" generic="16" specific="6" roletype="5" devicetype="5376" nodetype="0" type="Valve Open Close" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Configuration">
        <Manufacturer id="152" name="G.R.">
            <Product type="3" id="512" name="GR105n Auto Valve" />
        </Manufacturer>
        <CommandClasses>
            <CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="4" innif="true" mapping="37">
                <Instance index="1" />
            </CommandClass>
            <CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="4" innif="true">
                <Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
            </CommandClass>
            <CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="4" innif="true">
                <Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="3" size="1">
                    <Item label="Disabled" value="0" />
                    <Item label="Off Enabled" value="1" />
                    <Item label="On Enabled" value="2" />
                    <Item label="On and Off Enabled" value="255" />
                </Value>
            </CommandClass>
            <CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="4" innif="true">
            </CommandClass>
            <CommandClass id="94" name="COMMAND_CLASS_ZWAVE_PLUS_INFO" version="1" request_flags="4" innif="true">
                <Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
                <Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="5376" />
                <Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="5376" />
            </CommandClass>
            <CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="4" innif="true">
            </CommandClass>
            <CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="4" innif="true">
                <Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
                    <Item label="Normal" value="0" />
                    <Item label="-1dB" value="1" />
                    <Item label="-2dB" value="2" />
                    <Item label="-3dB" value="3" />
                    <Item label="-4dB" value="4" />
                    <Item label="-5dB" value="5" />
                    <Item label="-6dB" value="6" />
                    <Item label="-7dB" value="7" />
                    <Item label="-8dB" value="8" />
                    <Item label="-9dB" value="9" />
                </Value>
                <Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
                </Value>
                <Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
                <Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
                    <Item label="Failed" value="0" />
                    <Item label="Success" value="1" />
                    <Item label="In Progress" value="2" />
                </Value>
                <Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
            </CommandClass>
            <CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="4" innif="true">
                <Associations num_groups="1">
                    <Group index="1" max_associations="5" label="Lifeline" auto="true">
                        <Node id="1" />
                    </Group>
                </Associations>
            </CommandClass>
            <CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="4" innif="true">
                <Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="6" />
                <Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.05" />
                <Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.02" />
            </CommandClass>
        </CommandClasses>
    </Node>
sudo service domoticz start
That's all! Everything is working!
gr105n.xml
(1.39 KiB) Downloaded 154 times
