Important edit :
-- DO NOT USE THE BELOW CODE on Login.HTML -->> IT CREATES A SECURITY RISK !!! --
(better use similar in index.html, tested and no security risk so far discovered)
I suffer from some annoying people and bots that try to login to domoticz from all over the world. Mostly Azia, America, Africa)
Luckey they did not succeed and i have set up allready a VPN service to avoid it
Never the less i was thinking of a nice "improvement"/adjustment to avoid this and i wanted to share for anyone that can benefit from it.
The code i have implemented in login.html just after </style> :
<script>
function mijnding(){
<!-- Detect local or not -->
$.get("https://ipinfo.io", function(response) {
console.log(response.ip);
document.getElementById("IP").innerHTML = response.ip;
document.getElementById("Country").innerHTML = response.country;
if (response.country != 'NL' ) {$(location).attr('href', 'http://hmpg.net/') }
}, "jsonp");
mijnding()
</script>
<center>
<Div id="IP" style="font-size:70%"></Div>
<Div id="Country" style="font-size:70%"></Div>
</center>
(edit : corrected typo)
