How to program Chuango RC-80 (4-button remote)?
Posted: Friday 12 May 2017 21:02
by sammyke007
Hi guys
Messing with Domoticz and my new RFlink since this week and I love it.
I'm already able to control all of my Kakulights, Milights and my Somfy RTS blinds thanks to the available great guides.
I have a Chuango alarm system in my house and I won't succes in programming this remote.
It has 4 buttons:
- Activate (ARM)
- Activate home (ARM without PIR)
- Deactivate
- Panic
These 4 buttons each have their own codes and I see them when scanning and I can add them as switches, HOWEVER...
My Chuango alarm only picks up the signal when I quickly click(spam) the switch 3 times in a row in Domoticz...
Any solution to make the RFlink transmit the signal a little bit longer?
Tnx in advance!
Re: How to program Chuango RC-80 (4-button remote)?
Posted: Friday 12 May 2017 22:05
by deennoo
That a choice to do not allow to copy this remote and allowing to full controle your alarm main system with lighter and warner.
Posted: Saturday 13 May 2017 13:10
by sammyke007
If I send the RF command 3x in a row, it works, however I can't seem to write a script that can send the command 3x when it's clicked...
I was thinking about
if devicechanged['AlarmOff'] == 'Off' then
commandArray['AlarmOff']='On'
commandArray[1]={['AlarmOff']='On'}
commandArray[2]={['AlarmOff']='On'}
commandArray[3]={['AlarmOff']='On'}
But it doesn't work...
Posted: Saturday 13 May 2017 13:30
by pvm
You can create a shell script which executes json calls to Domoticz with a short delay in between and add that to the on action of a button. It might however be blocking the event handling of Domoticz during execution
Posted: Tuesday 16 May 2017 17:14
by sammyke007
This did the trick!
if devicechanged['AlarmOff'] == 'On' then
commandArray["AlarmOff"]='Off REPEAT 2 INTERVAL 0.5'
where AlarmOff is a switch that's sending the remote's "Off" code.
Posted: Friday 06 August 2021 16:38
by jurgend
sammyke007 wrote: Friday 12 May 2017 21:02
Hi guys
It has 4 buttons:
- Activate (ARM)
- Deactivate
- Panic
Tnx in advance!
Hi, I have the eTiger version (they are from the same manufacturors) Could you please tell me what your RFLink settings are and how I can add the remote?
