How to program Chuango RC-80 (4-button remote)?
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
Hi guys
Messing with Domoticz and my new RFlink since this week and I love it.
I'm already able to control all of my Kakulights, Milights and my Somfy RTS blinds thanks to the available great guides.
I have a Chuango alarm system in my house and I won't succes in programming this remote.
It has 4 buttons:
- Activate (ARM)
- Activate home (ARM without PIR)
- Deactivate
- Panic
These 4 buttons each have their own codes and I see them when scanning and I can add them as switches, HOWEVER...
My Chuango alarm only picks up the signal when I quickly click(spam) the switch 3 times in a row in Domoticz...
Any solution to make the RFlink transmit the signal a little bit longer?
Tnx in advance!
deennoo
Re: How to program Chuango RC-80 (4-button remote)?
Post by deennoo »
That a choice to do not allow to copy this remote and allowing to full controle your alarm main system with lighter and warner.
http://domo-attitude.fr
sammyke007
If I send the RF command 3x in a row, it works, however I can't seem to write a script that can send the command 3x when it's clicked...
I was thinking about
if devicechanged['AlarmOff'] == 'Off' then
            commandArray['AlarmOff']='On'
            commandArray[1]={['AlarmOff']='On'}
            commandArray[2]={['AlarmOff']='On'}
            commandArray[3]={['AlarmOff']='On'}
But it doesn't work...
pvm
Domoticz version: 4.10538
Post by pvm »
You can create a shell script which executes json calls to Domoticz with a short delay in between and add that to the on action of a button. It might however be blocking the event handling of Domoticz during execution
sammyke007
This did the trick!
if devicechanged['AlarmOff'] == 'On' then
        commandArray["AlarmOff"]='Off REPEAT 2 INTERVAL 0.5'
where AlarmOff is a switch that's sending the remote's "Off" code.
jurgend
Post by jurgend »
sammyke007 wrote: Friday 12 May 2017 21:02 Hi guys
It has 4 buttons:
- Activate (ARM)
- Deactivate
- Panic
Tnx in advance!
Hi, I have the eTiger version (they are from the same manufacturors) Could you please tell me what your RFLink settings are and how I can add the remote?
