How to see hidden devices? Topic is solved
markk
I'm sorry if this is a stupid question. I've tried searching the forum for the answer. My switches page was getting very cluttered so I recently starting hiding some some dummy switches by putting a $ in front of them. I know need to edit one of them but don't know where to find it
. Would be grateful if someone could help please.
mark.sellwood
Re: How to see hidden devices?
Hi, Go in to Setup then Devices, select All Devices the put a $ in the search box, you should then see all your hidden devices.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
markk
Ok, thanks. I'll check this out when I get home. Will I be able to edit them from here too then?
mark.sellwood
Yep, there is a pencil icon that allows you to edit its name.
markk
Got it. Thanks for that.
