best thermostat for domoticz
Posted: Friday 12 May 2017 10:34
by italoc
i need to buy a smart thermostat, i and i would like to buy a thermostat that works with domoticz and homekit...
which is the best product?
thanks
Re: best thermostat for domoticz
Posted: Friday 12 May 2017 10:41
by maomanna
would be nice if you tell something about your CV system.
Is it openTherm, on/off etc.
Posted: Friday 12 May 2017 10:48
by albamatti
I use ThermoSmart. Is OpenTherm and can be used through HomeKit and with Siri
Posted: Friday 12 May 2017 12:29
by italoc
albamatti wrote:I use ThermoSmart. Is OpenTherm and can be used through HomeKit and with Siri
this one
https://www.robbshop.nl/thermosmart-ope ... hermostaat ??
Posted: Friday 12 May 2017 17:25
by italoc
maomanna wrote:would be nice if you tell something about your CV system.
it isn't openTherm, I have 3 on/off thermostat
Posted: Friday 12 May 2017 17:34
by emme
for my small bathroom I'm looking for a thermostat which is supposed to activate only a heater...
actually I have a virtual SP and a shedule that trigger a heater lamp until a rf433 thermometer rise to the wanted temp... that's fine.. it works... BUT... I cannot phisically (manually) setup the temp unless I do not do that acting to domoticz (in any way)
My intention would be to create a device (ESP8266 on NodeMCU) with a display showing the actual temp, the setpoint, date/time and 3 buttons: up/down/reset
the main problem is that I don't know how to do that
Posted: Thursday 14 September 2017 12:27
by blauwebuis
What's the best option for an on-off heater?
Posted: Thursday 14 September 2017 13:06
by blauwebuis
Wow, I just discovered the Smart Virtual thermostat plugin for Domoticz. It looks awesome!!
https://www.domoticz.com/wiki/Plugins/S ... ostat.html
Posted: Thursday 14 September 2017 16:11
by tlpeter
Which uses python and python doesn't work anymore (in the beta's)
Posted: Wednesday 27 September 2017 13:22
by cyberclwn
blauwebuis wrote: Thursday 14 September 2017 12:27
Not sure if it is "the best" option, but i use a couple of these
http://www.homewizard.nl/smartwares-dra ... kraan.html.
Don't use any of the scheduling posibilities on the valve, i just let domoticz set the temperature (14 at night, 19 at day) if it is lower then what i want (with a seperate thermometer).
This is to reduce the switch moment, no need to turn valve to 19 degrees if it is 22 (in summer) already ...
Posted: Tuesday 03 October 2017 22:28
by timh1004
I‘m using the Smart Thermostat by Netatmo. It is not the cheapest, but it looks great, works very well and has an out of the box support by Domoticzs.
https://www.netatmo.com/product/energy/thermostat
