best thermostat for domoticz
italoc
i need to buy a smart thermostat, i and i would like to buy a thermostat that works with domoticz and homekit...
which is the best product?
thanks
thanks
maomanna
Re: best thermostat for domoticz
would be nice if you tell something about your CV system.
Is it openTherm, on/off etc.
albamatti
- Domoticz version: 2020.1
I use ThermoSmart. Is OpenTherm and can be used through HomeKit and with Siri
italoc
albamatti wrote:I use ThermoSmart. Is OpenTherm and can be used through HomeKit and with Siri
this one https://www.robbshop.nl/thermosmart-ope ... hermostaat ??
italoc
it isn't openTherm, I have 3 on/off thermostatmaomanna wrote:would be nice if you tell something about your CV system.
- emme
- Domoticz version: latest
for my small bathroom I'm looking for a thermostat which is supposed to activate only a heater...
actually I have a virtual SP and a shedule that trigger a heater lamp until a rf433 thermometer rise to the wanted temp... that's fine.. it works... BUT... I cannot phisically (manually) setup the temp unless I do not do that acting to domoticz (in any way)
My intention would be to create a device (ESP8266 on NodeMCU) with a display showing the actual temp, the setpoint, date/time and 3 buttons: up/down/reset
the main problem is that I don't know how to do that
"We always done this way"
blauwebuis
- Domoticz version: current
What's the best option for an on-off heater?
blauwebuis
Wow, I just discovered the Smart Virtual thermostat plugin for Domoticz. It looks awesome!!
https://www.domoticz.com/wiki/Plugins/S ... ostat.html
tlpeter
Which uses python and python doesn't work anymore (in the beta's)
- cyberclwn
- Domoticz version: 2024.4
Not sure if it is "the best" option, but i use a couple of these http://www.homewizard.nl/smartwares-dra ... kraan.html.
Don't use any of the scheduling posibilities on the valve, i just let domoticz set the temperature (14 at night, 19 at day) if it is lower then what i want (with a seperate thermometer).
This is to reduce the switch moment, no need to turn valve to 19 degrees if it is 22 (in summer) already ...
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
timh1004
I‘m using the Smart Thermostat by Netatmo. It is not the cheapest, but it looks great, works very well and has an out of the box support by Domoticzs.
https://www.netatmo.com/product/energy/thermostat
