Dashticz - Safety (no access from outside your network)
Posted: Tuesday 09 May 2017 20:27
by lukev
This afternoon a dashticz user pointed me to quite a security breach in my setup. My dasboard was placed on a webserver, which was accesable from the internet (because I host serveral websites).
Via this method it's fairly easy to read personal information like login credentials and/or API-codes.
I removed the dashboard from my webfolder, but now I am looking for an alternative way to safely acces the dashboard, only from within my own house. The WWW-folder of domoticz is not an option, because domoticz itself is accesable from the internet (with login). That comes in handy sometimes to put on light, heating, etc. Or to read out motion sensors when the alarm triggers.
But placed in the WWW-directory, all the credentials are also readable.
I can place the files somewhere else on my network, but then I have problems with showing the dashboard on my dedicated android tab in my house. By my knowledge it (e.g. Chrome) cannot show webfiles from a random network location.
So my question: how do you guys safely use this dashboard??
Re: Dashticz - safety
Posted: Tuesday 09 May 2017 21:03
by Ierlandfan
Just to make sure:
You mean that
http://192.168.x.y/dashticz/index.html
cannot be displayed by your android device?
Posted: Tuesday 09 May 2017 21:33
by niceandeasy
I just placed an .htaccess file in the root of my Dashticz directory on my web server.
If your webserver runs on Apache, this should work. If you're running an old version of Apache, you may need to use a different syntax (google it), or just update your Apache.
so, the file name is: .htaccess
it contains this line: Require ip 192.168.1.0/24
Where 192.168.1.0/24 (or 192.168.1.x mask 255.255.255.0) is your own network.
It is not ideal, it shows an http 403 error instead of 404 but at least it is inaccessible. It also blocks the contents of Dashticz's subdirectories.
Posted: Tuesday 09 May 2017 22:19
by lukev
Yes it can, but that requires for the index.html to be on a webserver?
If I put it somewhere else on my network, it would require Some other protocol like smb or nfs or something like that.
Re: Dashticz - Safety (no access from outside your network)
Posted: Tuesday 09 May 2017 22:33
by robgeerts
Use the htaccess solution from @niceandeasy on your webserver...
Posted: Tuesday 09 May 2017 22:43
by HansieNL
I'm using a Raspberry Pi running Domoticz and have also lighttpd installed as 2nd webserver just for internal use. There are no ports forwarded to this webserver so should be safe.
Posted: Friday 12 May 2017 20:06
by asjmcguire
It's trivial to install Nginx or Apache or something on any computer - including the Domoticz one - and host other web content - that is not accessible from the internet. You just have to make sure it's being served on a port that the router is not port forwarding.
Nginx:
https://www.digitalocean.com/community/ ... untu-16-04
Posted: Sunday 14 May 2017 11:48
by Grove
On Synology the .htaccess method isn't working for me.
Is there someone that has this successfully implemented on a Synology?
Posted: Sunday 14 May 2017 12:05
by qwerk
I have used a dutch manual yesterday. that worked for me.
https://www.synology.com/nl-nl/knowledg ... ged_access
Posted: Sunday 14 May 2017 12:42
by Egregius
Grove wrote:On Synology the .htaccess method isn't working for me.
.htaccess works only with Apache 2.2 on a Syno
Posted: Sunday 14 May 2017 15:26
by Grove
The apache backend is configured as version 2.2. But the .htacces doesn't have any effect. So I was wondering if somebody had this implemented and how.
Verstuurd vanaf mijn SM-G950F met Tapatalk
Posted: Sunday 14 May 2017 15:42
by qwerk
Grove wrote:The apache backend is configured as version 2.2. But the .htacces doesn't have any effect. So I was wondering if somebody had this implemented and how.
HI Grove,
did you follow the manual I gave ( two replies above) ?
I followed it step by step and it is working on synology 6.1 and apache 2.2 backend
Posted: Sunday 14 May 2017 20:29
by Grove
Hi Qwerk,
Did you do it on the Dashticz site?
On others sites, I did already implement a password requirement for accessing it but on the dashticz it isn't working for some reason.
Posted: Sunday 14 May 2017 20:49
by lukev
Strange, im on a synology and the htaccess-solution works for me
Posted: Sunday 14 May 2017 22:02
by qwerk
Grove wrote:Hi Qwerk,
my domoticz is running on a pi, but dashticz is running om a synology.
the dashticz site is protected by htaccess.
So, your synology can handle htaccess for a number of sites.
dashticz is also running on the same synology.
you have apache 2.2 as backend,do you have php configured?
is there any nginx running?
can you access your dashticz site?
Posted: Monday 15 May 2017 12:31
by Grove
Hi qwerk,
I've copied the directory from ..../domoticz/www to .../web from the Synology itself and now it is working.
I think domoticz is running on a nginx server.
Thanks for your support
Posted: Tuesday 01 August 2017 0:57
by niceandeasy
Grove wrote:Hi qwerk,
This is how I did it, too.
Domoticz lives on a Raspberry. Dashticz is on my web server: a Synology. The Syno has Apache and supports .htaccess. Domoticz does not.
Posted: Friday 11 August 2017 14:40
by Dynamic
Is there a way to protect Dashticz on a Raspberry?
Posted: Tuesday 15 August 2017 10:19
by edwin
Dynamic wrote: Friday 11 August 2017 14:40
As far as I understand, your would need to run a separate webserver that uses htaccess or something similar (like nginx). The Domoticz internal webserver does not use it.
For my own setup, I don't have any access setup from outside, except ssh. I access my setup using port forwarding.
Posted: Friday 25 August 2017 11:42
by Luxtux
the htaccess idea works or you could put the dashticz dashboard outside of your publicly available site root and add an alias that can only be accessed from within your own network or even just by specific ip addresses.
example: /etc/apache2/sites-available/mydomain.conf
<VirtualHost *:80>
ServerAdmin [email protected]
DocumentRoot /var/www/mydomain
ServerAlias mydomain.com
Alias /dashboard/ "/var/www/dashboard/"
<Directory "/var/www/dashboard/">
Order deny,allow
Deny from all
Allow from 10.10.10 # allow all ip addresses
Allow from 192.168.0.5 # allow only this ip
</Directory>
</VirtualHost>
everybody outside of your network will get this error
