Dashticz - Safety (no access from outside your network)
lukev
Post by lukev »
This afternoon a dashticz user pointed me to quite a security breach in my setup. My dasboard was placed on a webserver, which was accesable from the internet (because I host serveral websites).
Via this method it's fairly easy to read personal information like login credentials and/or API-codes.
I removed the dashboard from my webfolder, but now I am looking for an alternative way to safely acces the dashboard, only from within my own house. The WWW-folder of domoticz is not an option, because domoticz itself is accesable from the internet (with login). That comes in handy sometimes to put on light, heating, etc. Or to read out motion sensors when the alarm triggers.
But placed in the WWW-directory, all the credentials are also readable.
I can place the files somewhere else on my network, but then I have problems with showing the dashboard on my dedicated android tab in my house. By my knowledge it (e.g. Chrome) cannot show webfiles from a random network location.
So my question: how do you guys safely use this dashboard??
Ierlandfan
Re: Dashticz - safety
Post by Ierlandfan »
Just to make sure:
You mean that
http://192.168.x.y/dashticz/index.html
cannot be displayed by your android device?
niceandeasy
Domoticz version: 3.8153
Post by niceandeasy »
I just placed an .htaccess file in the root of my Dashticz directory on my web server.
If your webserver runs on Apache, this should work. If you're running an old version of Apache, you may need to use a different syntax (google it), or just update your Apache.
so, the file name is: .htaccess
it contains this line: Require ip 192.168.1.0/24
Where 192.168.1.0/24 (or 192.168.1.x mask 255.255.255.0) is your own network.
It is not ideal, it shows an http 403 error instead of 404 but at least it is inaccessible. It also blocks the contents of Dashticz's subdirectories.
lukev
Post by lukev »
Ierlandfan wrote:
Just to make sure:
You mean that
Yes it can, but that requires for the index.html to be on a webserver?
If I put it somewhere else on my network, it would require Some other protocol like smb or nfs or something like that.
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Safety (no access from outside your network)
Post by robgeerts »
Use the htaccess solution from @niceandeasy on your webserver...
HansieNL
Post by HansieNL »
I'm using a Raspberry Pi running Domoticz and have also lighttpd installed as 2nd webserver just for internal use. There are no ports forwarded to this webserver so should be safe.
Blah blah blah
asjmcguire
Domoticz version: 3.5877
Post by asjmcguire »
It's trivial to install Nginx or Apache or something on any computer - including the Domoticz one - and host other web content - that is not accessible from the internet. You just have to make sure it's being served on a port that the router is not port forwarding.
Nginx: https://www.digitalocean.com/community/ ... untu-16-04
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
Grove
Post by Grove »
On Synology the .htaccess method isn't working for me.
Is there someone that has this successfully implemented on a Synology?
qwerk
Post by qwerk »
I have used a dutch manual yesterday. that worked for me.
https://www.synology.com/nl-nl/knowledg ... ged_access
Egregius
Domoticz version: v2024.7
Post by Egregius »
Grove wrote:On Synology the .htaccess method isn't working for me.
.htaccess works only with Apache 2.2 on a Syno
Grove
Post by Grove »
The apache backend is configured as version 2.2. But the .htacces doesn't have any effect. So I was wondering if somebody had this implemented and how.
Verstuurd vanaf mijn SM-G950F met Tapatalk
qwerk
Post by qwerk »
Grove wrote:The apache backend is configured as version 2.2. But the .htacces doesn't have any effect. So I was wondering if somebody had this implemented and how.
HI Grove,
did you follow the manual I gave ( two replies above) ?
I followed it step by step and it is working on synology 6.1 and apache 2.2 backend
Grove
Post by Grove »
Hi Qwerk,
Did you do it on the Dashticz site?
On others sites, I did already implement a password requirement for accessing it but on the dashticz it isn't working for some reason.
lukev
Post by lukev »
Strange, im on a synology and the htaccess-solution works for me
qwerk
Post by qwerk »
Grove wrote:Hi Qwerk,
my domoticz is running on a pi, but dashticz is running om a synology.
the dashticz site is protected by htaccess.
So, your synology can handle htaccess for a number of sites.
dashticz is also running on the same synology.
you have apache 2.2 as backend,do you have php configured?
is there any nginx running?
can you access your dashticz site?
Grove
Post by Grove »
Hi qwerk,
I've copied the directory from ..../domoticz/www to .../web from the Synology itself and now it is working.
I think domoticz is running on a nginx server.
Thanks for your support
niceandeasy
Grove wrote:Hi qwerk,
This is how I did it, too.
Domoticz lives on a Raspberry. Dashticz is on my web server: a Synology. The Syno has Apache and supports .htaccess. Domoticz does not.
Dynamic
Post by Dynamic »
Is there a way to protect Dashticz on a Raspberry?
edwin
Post by edwin »
Dynamic wrote: Friday 11 August 2017 14:40 Is there a way to protect Dashticz on a Raspberry?
As far as I understand, your would need to run a separate webserver that uses htaccess or something similar (like nginx). The Domoticz internal webserver does not use it.
For my own setup, I don't have any access setup from outside, except ssh. I access my setup using port forwarding.
Recent beta (git) on Arch Linux | Dashticz v2 (git) | RFLink 46.0 | Ikea Trådfri | P1 Smart Meter
Luxtux
Domoticz version: 2021.1 β
Post by Luxtux »
the htaccess idea works or you could put the dashticz dashboard outside of your publicly available site root and add an alias that can only be accessed from within your own network or even just by specific ip addresses.
example: /etc/apache2/sites-available/mydomain.conf
<VirtualHost *:80>
	ServerAdmin [email protected]
	DocumentRoot /var/www/mydomain
	ServerAlias mydomain.com
        Alias /dashboard/ "/var/www/dashboard/"
        <Directory "/var/www/dashboard/">
    	    Order deny,allow
    		Deny from all
		Allow from 10.10.10 # allow all ip addresses
		Allow from 192.168.0.5 # allow only this ip
        </Directory>
</VirtualHost>
everybody outside of your network will get this error
