Wake up Light
Mavy
Wake up Light
Post by Mavy »
Hi Everyone,
I was wondering if anyone has managed to create some sort of wake up light using domoticz yet. I tried to create one but all my efforts so far have failed.
At first i tried to use a blocky based event, however I seem to be missing a basic function in the blocky event builder. That function being a delay between set actions.
Then i tried to use lua, however this hangs the entire domoticz process due to it not being forked as a separate thread (for which i will file a bug later because imo thats a major flaw).
After this i attempted to use the bash script, however this would need an extensive script to fetch device status using curl/json (which seems to lack support to fetch a single device?). Unless its the only option i am not yet willing to try this due to the load it will put om my poor raspberry pi :?
Are there any other ideas/solutions to doing this?
I played with the idea of creating several virtual devices to trigger each new level but that would create a mess of dummy switches and i cannot think of anyway to add the delay between levels.
Regards,
Mavy
alfred_j_kwak
Domoticz version: 2.3530
Re: Wake up Light
Post by alfred_j_kwak »
Mavy
Re: Wake up Light
Post by Mavy »
I did see that thread but that script kind of defeats the purpose of domoticz. Plus it has a similar issue as the bash script i mentioned earlier. There is no decent way to get a single device status using json.
simonrg
Domoticz version: 3.8807
Re: Wake up Light
Post by simonrg »
@Mavy, please could you share the scripts you have tried, this will make it easier to help :)
Mavy
Re: Wake up Light
Post by Mavy »
The original script i tried was:
if (devicechanged['Bedroom Rene Wakeup'] == 'On') then
     if (otherdevices['Bedroom Rene Light'] == 'Off') then
             print("Wake up light on!")
             for i = 1, 16, 1 do
                     print("Setting Level: "..i)
                     oss = "curl 'http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=4&switchcmd=Set+Level&level="..i.."'&"
                     os.execute(oss)
                     os.execute("sleep 60")
     commandArray['Bedroom Rene Wakeup'] = 'Off'
However domoticz would hang completely during the sleep. My guess is that the lua code gets run inside the main process loop instead of as a fork/thread.
I then tried a bash script but its hard to process all the json code returned by the json scripts.
Currently i am planning to use the following:
local http = require("socket.http")
JSON = (loadfile "JSON.lua")()
local function get_status(idx)
        url = 'http://127.0.0.1:8080/json.htm?type=devices&filter=light&used=true&order=Name'
        b, c, h = http.request(url)
        local o = JSON:decode(b)
        for key,value in pairs(o["result"]) do
                if value["idx"] == idx then
                        return value["Status"]
local function set_device(idx, level)
        seturl = 'http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx='..idx..'&switchcmd=Set+Level&level='..level
        b, c, h = http.request(seturl)
local function wait(seconds)
        local _start = os.time()
        local _end = _start+seconds
        while (_end ~= os.time()) do
status = get_status("4")
if status ~= "Off" then return end
for i = 2, 16, 1 do
        set_device("4", i)
        wait(120)
        if status == "Off" or status == "On" then print (status) return end
I plan on running this from the os lua. Probably using the domoticz_main script. I just need to test if this will hang the rest of the process as well. If it does i am out of ideas.
simonrg
Re: Wake up Light
Post by simonrg »
Nice, thanks, what does JSON.lua have in it?
I have changed your script from a device to a time script, so every 60 seconds Domoticz will check the state of the wakeup switch, if it is on then, Domoticz will increase the light level by 1 for every 60 seconds since the wakeup switch was turned on, until at 16 minutes it will turn the wakeup switch off. So while Domoticz will check the script every 60 seconds all day nothing will happen unless the wakeup switch is on.
I haven't tested this script, so hope there aren't too many errors.
-- ~/domoticz/scripts/lua/script_time_wakeup.lua
-- If the wakeup switch is on
-- Then increases the lighting by 1 level every 60 seconds
-- After 8 minutes turns the wakeup switch off
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
if (otherdevices['Bedroom Rene Wakeup'] == 'On') then
     wake_time = timedifference(otherdevices_lastupdate['Bedroom Rene Wakeup'])
     level = 1 + wake_time % 60
     if(level <= 16) then
         commandArray['Bedroom Rene Light'] = 'Set Level '..level
        commandArray['Bedroom Rene Wakeup'] == 'Off'
Thanks for the chance to think about this challenge, it has now inspired me to generalise this code, so if I create a switch called "Wakeup Room Name" then the Lua script will get Domoticz to check all "Wakeup ....." switches, and do the level changing on each "Wakeup...." switch which is on. I have already written similar code for PIRs, so it is just a matter of adding the bits together and then we have the ultimate "Wakeup...." switch ;) . So then any light could have a wakeup sequence just by creating a new "Wakeup Room Name" switch in Domoticz. See http://www.domoticz.com/forum/viewtopic ... 348&p=9003
Mavy
Re: Wake up Light
Post by Mavy »
Oh nice idea, i hadn't thought of using the last update. The json code is here http://regex.info/blog/lua/json
simonrg
Re: Wake up Light
Post by simonrg »
Thanks for JSON reference.
I have now written a quick general version - the Ultimate Smart WakeUp (tm) :lol: - "WakeUpxroom name" - when switched on will increase the level of "room name" linearly over 800 seconds until the light is fully on, at which point "WakeUpxroom name" will be switched off. x^2 is the number of minutes the wake-up will take, not sure this is ideal, but from 1, 4, 9, 16, 25, 36, 49, 64 and 81 minutes give a number of choices anyway.
-- There is no error checking, so case of letters, spacing and correct characters in locations are key
-- If it doesn't work check for errors in the log
-- This script needs two switches to exist in Domoticz
-- A switch for the room with any legitimate Domoticz name "Room Name"
-- A dummy switch to start the wake-up sequence - "WakeUpxRoom Name"
-- Where x should be replaced by a single number and determines
-- number of minutes taken to reach full intensity
-- Time = x^2 * 60 seconds, so 4 is 16 minutes, 5 is 25 minutes etc..
-- e.g. Setting the WakeUp4Room Name" switch to on
-- Then the light intensity increases 1/16 every 60 seconds
-- After 16 minutes turns the wakeup switch off
   print("s "..s)
   t1 = os.time()
   print("t1 "..t1)
   print("t2 "..t2)
   return difference
for i, v in pairs(otherdevices) do
   tc = tostring(i)
   v = i:sub(1,6)
   if (v == 'WakeUp') then
      if (otherdevices[tc] == 'On') then
         time_range = 60 * tonumber(i:sub(7,7))^2
         print("Time range "..time_range)
         wake_time = timedifference(otherdevices_lastupdate[tc])
         print("Wake Time "..wake_time)
         level = 100 * (wake_time / time_range)
         print(level)
         if(level <= 100) then
            print('Set Level '..string.format("%u",level))
            commandArray[tc:sub(8)] = 'Set Level '..string.format("%u",level)
            commandArray[tc:sub(8)] = 'Set Level 100'
            commandArray[tc] = 'Off'
Remove all the print statements when you are happy the script is working correctly.
Mavy
Re: Wake up Light
Post by Mavy »
I would add a check in the loop to check if a light is Off before starting to dim it. This is to prevent the wakeup from starting if the light is already On.
Another thing i would do is add a condition to stop the wake up sequence if the light is turned Full On or Off (So your able to turn the "alarm" off when your awake)
simonrg
Re: Wake up Light
Post by simonrg »
Thanks, good additions, I am using LightwaveRF components, so there is no feedback, hence status in Domoticz is not necessarily the state of the light, so I probably won't add the checks on light condition.
To turn the alarm off, it would be cleanest to set the WakeUp switch to off, so a check in the script for state at 100% which would then set WakeUp off. In the case of LightwaveRF in order to ensure the light was really on I would need to send a 100% on command, so on somedays you would get a rapid wake-up ;) .
havnegata
Domoticz version: V4.10162
Re: Wake up Light
Post by havnegata »
I've been looking for this script a long time (all I do is steal and modify :oops: ) and so was very glad when I found yours . I change the names of the switches and I get this error:
Error: EventSystem: C:\Domoticz\scripts\lua\script_time_wakeup.lua:27: syntax error near '=='
Any clues?
t1 = os.time()
return difference
if (otherdevices['Soverom Wakeup'] == 'On') then
wake_time = timedifference(otherdevices_lastupdate['Soverom Wakeup'])
commandArray['Dimmer soverom'] = 'Set Level '..level
commandArray['Soverom Wakeup'] == 'Off'
G3rard
Domoticz version: No
Re: Wake up Light
Post by G3rard »
Remove one = from line 27 so it is like below.
commandArray['Soverom Wakeup'] = 'Off'
The error message gives the line number on which the error occurs, so 27 in this case. That makes finding the error a bit easier.
Not using Domoticz anymore
havnegata
Re: Wake up Light
Post by havnegata »
Ok, thanks, that makes sense :-)
When I try this, the error is gone, but the only thing that happens with the script is that the dummy switch is turned off.. Any more clues?
Pjedr
Re: Wake up Light
Post by Pjedr »
I created a wakeuplight also in bash, via dummy switch on action: script:///var/ramdrive/scripts/WakeUpLightStart.sh
WakeUpLightStart.sh (This script calls the other script, so no 10 seconds limit)
#!/bin/bash
if [ -e "/var/ramdrive/domoticz" ]; then SCRIPTSDIR="/var/ramdrive/scripts"; else SCRIPTSDIR="/opt/scripts-test"; fi;
echo Starting Ambilight script; $SCRIPTSDIR/WakeUpLight.sh >/dev/null &
WakeUpLight.sh
#!/bin/bash
if [ -e "/var/ramdrive/domoticz" ]; then TOOLSDIR="/var/ramdrive/tools"; else TOOLSDIR="/home/peter/milight"; fi
# switch ON, WHITE, but to current state, that might be too high...  switch to lowest dim
zone2=2; $TOOLSDIR/milight $zone2 W; $TOOLSDIR/milight $zone2 B 1; sleep 0.2s; zone3=3; $TOOLSDIR/milight $zone3 W; $TOOLSDIR/milight $zone3 B 1
# change brightness from 1 to 19 in 20 steps of 5 seconds
for i in `seq 10`; do $TOOLSDIR/milight $zone2 B $i; sleep 0.2s; $TOOLSDIR/milight $zone3 B $i; sleep 30s; done
sleep 300; $TOOLSDIR/milight $zone2 B 1; $TOOLSDIR/milight $zone2 OFF; sleep 0.2s
$TOOLSDIR/milight $zone3 B 1; $TOOLSDIR/milight $zone3 OFF # lowering dim for the next morning and switching off after 300s
echo -e "\nVersturen van statuswijziging naar Domoticz server via json:"; sDomoticzServer="192.168.192.68:8080"
echo curl -s -i -m 5 -H "Accept: application/json" "http://$sDomoticzServer/json.htm?type=command&param=switchlight&idx=617&switchcmd=Off"
strCurl=`nice -n 10 curl -s -i -m 5 -H "Accept: application/json" "http://$sDomoticzServer/json.htm?type=command&param=switchlight&idx=617&switchcmd=Off"`
Same trick i use in lua scripts (the & starts a new console to run that command in, the current console ends in the 10 seconds limit):
os.execute('nohup '..sScriptsDir..'/TelegramBot.sh "'..sMsgTo..' '..sMsg..'" 2>/dev/null &')
Mrrodz
Re: Wake up Light
Post by Mrrodz »
Hi, did you get this working? Ive tried my self with no joy.
Fancy using it to cycle each light through 0-100-0% as a test. I currently have a lightwave system but struggling to get it working. Thanks
Sent from my iPhone using Tapatalk - now Free
Evelen
Domoticz version: 2.4538
Re: Wake up Light
Post by Evelen »
It is well possible in principle to make in Blockly.
Extremely many OPEN JSON URL blocks consecutively
With the same or just a little bit more dim every time.
Tested with 10-20 blocks and it works, but it's over in seconds.
One can, however, make it extremely long, but it might get out of the performance in Domoticz or?
I'm running on a real server though, not Pi.
maomanna
Re: Wake up Light
Post by maomanna »
I created a wiki several weeks ago how to make a wakeuplight with blockly.
Pretty long, but not an issue for a rpi!
Http://domoticz.com/wiki/wakeuplight
Evelen
Re: Wake up Light
Post by Evelen »
maomanna wrote:I created a wiki several weeks ago how to make a wakeuplight with blockly.
super.
btw. Can't other events run at the same time this is running?
maomanna
Re: Wake up Light
Post by maomanna »
Yes they can, but if you use the same devices, it can overrun each other.
Derik
Re: Wake up Light
Post by Derik »
Dear all...
What is the way/script to use a wake up and a sleep down light?
I see multiple options..
The best and simple way....
