Page 1 of 20
Dashticz - Feature Requests
Posted: Thursday 04 May 2017 23:00
by robgeerts
Add new feature request here.
I will extend this list with all requests, if it's not yet in here after a few days, please quote me
- Moving blocks from within the dashboard
- Adding blocks from within the dashboard
- RGB selector for colored lights
- StationClock
- Open camera on doorbell
- Different colors in the graphs
- Multiple versions of dashticz
Re: Dashticz - Feature Requests
Posted: Friday 05 May 2017 11:06
by htilburgs
@Robgeerts, you have been working on a color selecter (for hue)
http://www.domoticz.com/forum/viewtopic ... 80#p132112. Since yesterday I've a Yeelight Color RGBW Led in my Domoticz configuration.
When I add this to Dashticz I get a standard Dimmer whitout the posibility to change color (only dimmer and on/off function).
I've added the infomration from Domoticz.
- Spoiler: show
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 9,
"HardwareName" : "YeeLight Controller",
"HardwareType" : "YeeLight LED",
"HardwareTypeVal" : 91,
"HaveDimmer" : true,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "C0A80032",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2017-05-05 09:54:53",
"Level" : 99,
"LevelInt" : 99,
"MaxDimLevel" : 100,
"Name" : "Yeelight Huiskamer",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" : [ 2 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RGBW",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Lighting Limitless/Applamp",
"TypeImg" : "dimmer",
"Unit" : 0,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "267",
"YOffset" : "194",
"idx" : "213"
Request: Button like you've been working on in the added post.
Posted: Friday 05 May 2017 13:03
by HansieNL
3Quarks » Station Clock
http://www.3quarks.com/en/StationClock/
- Naamloos 1.jpg (22.73 KiB) Viewed 17502 times
Posted: Friday 05 May 2017 13:11
by robgeerts
Check out latest beta and add:
columns[1]['blocks'] = ['stationclock']
Posted: Friday 05 May 2017 13:19
by HansieNL
- thumbsammo03.jpg (55.9 KiB) Viewed 17483 times
Posted: Friday 05 May 2017 13:30
by bsmeding
Also added to GitHub (
https://github.com/robgeerts/dashticz_v2/issues/55), but it would be great to have an popup (for x seconds) of the camera when my (doorbell) switch in On so i can see in larger image who is at the frontdoor
Posted: Friday 05 May 2017 18:51
by clubeddie
Posted: Friday 05 May 2017 20:00
by pvdhelm
Maybe it's an option to make a frontpage where you can sellect a room when you press the button of the room the dashboard goes directly to the page of that room. After let say 1 minute it goes back to the frontpage
Posted: Friday 05 May 2017 20:17
by b00n
In my previous dashboard i got a doorbell function maybe rob can do something with is
function checkdoorbell(){
var idx=69
console.log("checking to see if Doorbell is On "+idx)
var xmlhttp = new XMLHttpRequest();
var url = "http://192.168.178.30:8080/json.htm?type=devices&rid="+idx;
var onoff
xmlhttp.onreadystatechange = function() {
if (xmlhttp.readyState == 4 && xmlhttp.status == 200) {
var myArr = JSON.parse(xmlhttp.responseText);
onoff = myArr.result[0].Status;
// myFunction(myArr);
if (onoff == "On") {
MM_goToURL('parent','cameras1.htm');
} else {}
Posted: Friday 05 May 2017 20:22
by lukev
Maybe a block for streaming video cams? Support of RTSP would be awesome, I have big problems with the image-based webcam possibilities at the moment.
Posted: Friday 05 May 2017 21:58
by b00n
Temp + Humidity in one box like:
- s.jpg (3.4 KiB) Viewed 17349 times
Posted: Saturday 06 May 2017 9:09
by woody4165
I would like to have the possibility to define an refresh time for weather, different than the Dashticz and Domoticz refresh that are already in the Config.js
Is it possible to do it in a simple way?
Posted: Saturday 06 May 2017 12:54
by capman
A have a question about the music controls. Is it possible to make the buttons larger for play , pause, etc... ? A have my Logitech media server on my synology nas and when a use squeezeplay on my phone , tablet ,a see a cover from what is playing with some radiostations. A think that these come from
http://www.tunein.com . These covers see a also on my LMS , so they must keep them from some online source.
Should it be possible to see these also on my dashboard screen ? A have searching for this a lot , but a found nothing how to do that. Maybe are here some users who are more capable for how to do this. Also thanks in advance.
Here some screenshot from my LMS where you see the whats playing cover.
- radio cover.JPG (50.88 KiB) Viewed 17276 times
And also from my dashticz so far.
- dashticz.JPG (351.24 KiB) Viewed 17265 times
Posted: Saturday 06 May 2017 19:18
by HansieNL
Rename of custom.css to custom_default.css and rename of custom.js to custom_default.js.
Now these custom files are overwritten by a new pull or zip unpack.
Posted: Sunday 07 May 2017 23:29
by poudenes
Use this clock, but when i switch screens the clock become black.
Posted: Monday 08 May 2017 15:01
by Blueone
The following improvement points would be nice:
-A better way to authenticate. Currently the format username:password@ip is used but it is a deprecated method which can't be used anymore from june.
-When you run the dashboard 24/7 a day it sometimes happens that domoticz can't be reached for whatever reason, bad wifi, domoticz busy or something. This result is an alert pop-up which stays in the screen. Maybe it better to write this error to the browser console log so the dashboard continuous
-While running 24/7 it sometimes happens the weather isn't loaded for whatever reason (api not available, internet hick-up) and is empty and the layout is messed up. A dashboard refresh fixes it. When you run 24/7 with a tablet on the wall you won't want to refresh the dashboard every 30 minutes as it is distractive. Maybe the refresh process can be more invisible without going out of stand-by are something. A bit the same as the domoticz refresh but not every few seconds, but a invisible refresh for the internet data every 10 minutes or so.
But overall, I really like this dashboard
Posted: Monday 08 May 2017 23:22
by clubeddie
Is it possible to show the costs of consumed power and gas?
These data is available in the log section of domoticz, and a user can adjust the kwh and m3 price of his supplier.
I don't know if this data can be extracted somehow?
No is also an answer
Posted: Tuesday 09 May 2017 13:02
by SwordFish
Is it possible to add custom colors for graph. Now i do this in the graph.js
Posted: Tuesday 09 May 2017 13:08
by robgeerts
clubeddie wrote:Is it possible to show the costs of consumed power and gas?
Do you get this data back from the json output?
http://URL_TO_DOMOTICZ/json.htm?type=devices
Posted: Tuesday 09 May 2017 13:18
by MarceldeJongNL
I would love to use one instance of Dashticz for multiple custom configurations (Desktop, Tablet, Phone, etc)
Could you make an option, to specify as specific Custom folder in the HTML file? Like a simple variable you put in the HTML file
Example:
index.html uses /custom (default)
mobile.html uses /custom_mobile
tablet_second_floor.html uses /custom_tablet_second_floor
That would make managing multiple instances a breeze
Thanks for all you effort!
