Weird calculation of time with os.date?
Olgmo
Domoticz version: 4.10717
Post by Olgmo »
I try to convert elapsed time from second into hours and minutes with os.date("%I:%M",diff)) but I dont understand why this is not working..
Command:
print ("UNIT Run time." .. diff .. " sec - " .. os.date("%H:%M",diff));
Log:
LUA: UNIT Run time. 306 sec - 01:05
WHY is 306 seconds display as 1 hour 5 minutes when it is just 5 minutes?
How to do this correctly?
zicht
Domoticz version: 2023.1+
Re: Weird calculation of time with os.date?
Post by zicht »
Try os.time :)
I do the same in different way, it has to do with lua and not with domoticz :)
os.clock is very accurate with up to 16 digits behind the comma.
z1 = os.clock()
code were you want to check how long it runs
print("*******  "..os.clock() - z1)
If you want to check on a device how long ago it was seen :
function timedifference (s)   --- tijdverschil bepalen sinds laatste schakeling in sec
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
To call the function you can use anywhere in you script:
difference2 = timedifference(otherdevices_lastupdate['Beweging Woonkamer'])
Both work like a charm and accurate.
Note : if you use the function for devicechanged_lastupdate{} you will run into an error on the day field, so always use otherdevices_lastupdate{} !
Note2 : if your code is running longer than 10 sec it will be abandoned to keep domoticz responsive
