Page 1 of 3
Sonoff Touch
Posted: Sunday 30 April 2017 20:41
by Eddiever
I have a Sonoff Touch wall switch. I would like to change it's firmware through ESP Easy. I have been searching but haven't found the right firmware. Due to the fact it is using the 8285 chip instead of 8266.
Does anyone have a suggestion?
Re: Sonoff Touch
Posted: Monday 01 May 2017 11:38
by mayyam
Re: Sonoff Touch
Posted: Monday 01 May 2017 18:53
by Eddiever
mayyam, thanks. I just flashed it. Now to replace it with the active touch which is in normal use. But do I cut the power or should I just replace the circuitboard with the wiring still alive? Just kidding, always with the power off.
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 20:53
by Eddiever
As I stated before I am very new and trying things out. Flashing worked. I can activate the ligth by hardware switch and from Domoticz. But somehow (I really don't know why) if I switch it manually the status in Domoticz won't change. Used some info from sincze
- Switch 1.PNG (18.07 KiB) Viewed 7680 times
- switch 2.PNG (18.01 KiB) Viewed 7680 times
On action Domoticz:
http://192.168.1.160/control?cmd=GPIO,12,1
I could really use some help. Who can?
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 20:58
by mayyam
That's my config.
And I also use Rules:
on System#Boot do
gpio,12,1
timerSet,1,1
endif
endon
on Rules#Timer=1 do
gpio,12,0
endon
on button#state do
if [button#state]=1
gpio,12,1
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
endif
endon
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 21:18
by Eddiever
Sorry mayyam, thought the code was from sincze.
Even if I set it up exactly like your example the state doesn't change within Domoticz. The IDX variable was wrong in my case. In Domoticz it has the value of 3. I changed that in both ESP devices.
From Domoticz:
- domoticz.PNG (121.15 KiB) Viewed 7677 times
What kind of stupid thing I am overlooking?
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 21:25
by mayyam
On ESPEasy, in button device You have to give idx of realay device in domoticz and check "Send data" chceck box.
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 21:34
by Eddiever
- sonoff touch 1.PNG (6.55 KiB) Viewed 7666 times
- esp 1.PNG (9.43 KiB) Viewed 7666 times
Changed it to 3 but still no state change when manually switched
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 21:41
by mayyam
Do You have "Send data" checked?
Also On Config tab: Protocol, Controller IP and Controller Port - do You have right values ?
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 21:47
by Eddiever
- Switch 1.PNG (17.98 KiB) Viewed 7664 times
- switch 2.PNG (18.01 KiB) Viewed 7664 times
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 21:49
by mayyam
And the Config tab?
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 21:53
by Eddiever
The config:
- config.PNG (22.48 KiB) Viewed 7661 times
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 21:56
by mayyam
If Your Domoticz server is 192.168.1.200, and port is 8080 it looks right to me.
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 22:01
by Eddiever
My server is indeed on 192.168.1.200 and the port is 8080. Thus it is strange
8080 is the default port, right?
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 22:08
by mayyam
Right.
I Have no Domoticz password, so my Controller User and Controller Pass fields are empty, but maybe You have to fill them ?
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 22:22
by Eddiever
Oh mayyam, how great (and stupid of me). That is it. Username/password. Darn me.
Thank you so much for your quick reply and help!
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 22:26
by mayyam
Try Rules. With Rules if Wifi will crash, Sonoff Touch will still work. Also, there is no latency when You switch it manually with Rules.
on button#state do
if [button#state]=1
gpio,12,1
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
endif
endon
I've also that rule:
on System#Boot do
gpio,12,1
timerSet,1,1
endif
endon
on Rules#Timer=1 do
gpio,12,0
endon
It's for telling me (one second blink) that there is power back if the electric company fu..ed up again.
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 22:31
by Eddiever
I have copied your rules and used them
Great to know Rules in combination with actions if wifi is out. Will dive into that later on.
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 22:33
by mayyam
You can also use the GPIO - 13 on the Wifi Status Led on the Hardware settings.
Re: Sonoff Touch
Posted: Tuesday 02 May 2017 22:37
by Eddiever
Already done that:
on System#Boot do
gpio,12,1
gpio,13,0
timerSet,1,1
endif
endon
on Rules#Timer=1 do
gpio,12,0
gpio,13,1
endon
on button#state do
if [button#state]=1
gpio,12,1
gpio,13,0
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
gpio,13,1
endif
endon
