Import RIVM sensor data
phoenixblue
Post by phoenixblue »
Small background info, because I life nearby chemical industy where it's most of the time safe ;) but for that one moment there is an problem I like to shutdown my mechanical ventilation at home.
So I have found that based on the website https://www.luchtmeetnet.nl/ the info from the RIVM is avalible to use (http://www.lml.rivm.nl/tabel/)
(sorry only usefull for the Netherlands)
From that part is possible to import the data into Domoticz, but therefore you must manual insert total 7 virtual text sensors with the next labels:
PM10 = Fijnstof (particulates)
O3 = Ozon (ozone)
NO = Stikstofmonoxide (nitric oxide)
CO = Koolstofmonoxide (carbon monoxide)
SO2 = Zwaveldioxide (sulfur dioxide)
NH3 = Ammoniak (Ammonia) -> (R717 for the Refrigeration engineers :) )
NO2 = Stikstofdioxide (nitrogen dioxide)
then inside the script:
1) set the idx codes at the right place.
2) set the used AirQuality location from the website nearby your location into the script (sorry it's in the bottem of the script)
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import xml.etree.ElementTree as ET
import requests
from requests.exceptions import ConnectionError
domoticz_devicesIdx = {"PM10": 1,
                       "O3": 2,
                       "NO": 3,
                       "CO": 4,
                       "SO2": 5,
                       "NH3": 6,
                       "NO2": 7
domoticz_server = "http://localhost"
domoticz_port = 8080
class AirQuality:
    def __init__(self, location):
        self.link = "http://www.lml.rivm.nl/xml/actueel.xml"
        self.location = location
        timedata = "http://www.lml.rivm.nl/xml/actueel-update.xml"
        z = requests.get(timedata)
        f = ET.fromstring(z.content)
        data = f.getchildren()[0].getchildren()[0].getchildren()
        year = data[0].text
        month = data[1].text
        day = data[2].text
        hour = data[3].text
        self.fetch()
        print "Fetching data from: %s/%s/%s, hour: %s" % (day, month, year, hour)
    def push(self, device, value):
        try:
            requests.get(
                "%s:%d/json.htm?type=command&param=udevice&idx=%d&nvalue=0&svalue=%s" %
                (domoticz_server, domoticz_port, device, value))
        except ConnectionError:
            print "I wasn't able to contact the domoticz server, is it up?"
    def fetch(self):
        # fetch the data and push it
        z = requests.get(self.link)
        elements = ET.fromstring(z.content).getchildren()[0].getchildren()
        components = {}
        for element in elements:
            data = element.getchildren()
            station = data[2].text
            component = data[3].text
            unit = data[4].text
            value = data[5].text
            if not (station.lower() == self.location.lower()):
                continue
            components[component] = '%s%s' % (value, unit)
        for component in domoticz_devicesIdx.keys():
            device = domoticz_devicesIdx[component]
            try:
                value = components[component]
            except KeyError:
                value = "n/a"
            self.push(device, value)
AirQuality("NL01489")
When you run the script it wil import al avalible data, when an sensor station has for an specific gas no sensor there will be send an n/a value.
At this moment there are an few point that must be changed in the future:
- text sensor to airquality sensor with the correct units.
- find out the save thresholds of the sensors and send it maybe to an alert level sensor.
assenzuid
Re: Import RIVM sensor data
Post by assenzuid »
I get below error
  File "airquality.py", line 71, in <module>
  File "airquality.py", line 34, in __init__
    self.fetch()
  File "airquality.py", line 69, in fetch
  File "airquality.py", line 42, in push
  File "/usr/lib/python2.7/dist-packages/requests/api.py", line 60, in get
    return request('get', url, **kwargs)
  File "/usr/lib/python2.7/dist-packages/requests/api.py", line 49, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 457, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 563, in send
    adapter = self.get_adapter(url=request.url)
  File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 642, in get_adapter
    raise InvalidSchema("No connection adapters were found for '%s'" % url)
requests.exceptions.InvalidSchema: No connection adapters were found for '192.168.1.xxx:8081/json.htm?type=command&param=udevice&i  dx=309&nvalue=0&svalue=n/a'
EdwinK
Post by EdwinK »
Thanks. Just something I was looking for, living very close to one of the chemical parts of the country (Botlek).
phoenixblue
EdwinK wrote:Thanks. Just something I was looking for, living very close to one of the chemical parts of the country (Botlek).
I think you can test it at this moment ;-)
Grote brand bij Esso in de Botlek
http://www.ad.nl/rotterdam/grote-brand- ... ~a00c1915/
EdwinK
Post by EdwinK »
Yes. Works :)
rbisschops
Domoticz version: 2.2563
Post by rbisschops »
Did you see this note:
De website www.lml.rivm.nl zal langzaam maar zeker zijn inhoud verliezen.
Recentelijk zijn de kaarten met een geinterpoleerde weergave van de meetdata al verwijderd.
Deze zijn namelijk ook te vinden op de gezamenlijke website.
Apparently the data will move to the other site.
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
Derik
Post by Derik »
mmm Is this sensor usefull after the lost of this data??
I cannot find my station [ Nijmegen keizerkarel ]
Looks a great script...
EdwinK
Post by EdwinK »
NL10741 RIVM Nijmegen-Graafseweg
NL10742 RIVM Nijmegen-Ruyterstraat
Use one of these.
Derik
Post by Derik »
EdwinK wrote: Tuesday 22 August 2017 20:54 NL10741 RIVM Nijmegen-Graafseweg
Use one of these.
Thanks...
Can i run with the internal interface or?
Where can i find the stations??
EdwinK
Post by EdwinK »
Station:
I created the script external, but I guess you can use the internal editor.
Derik
Post by Derik »
mmm internal is working by me...
@ Developer is it perhaps possible to use the internal Python options?
Derik
Post by Derik »
is it perhaps possible that the sensors send a notification??
So i can warn my kids there is smog or something??
What are the values that are good and what are bad values?
Derik
Post by Derik »
There is also a Roet in the data... Is there a option to use this data to?
And the Nijmegen sensor are both not working...
Derik
Post by Derik »
Looks like the sensors from Nijmegen are not in the list:
Perhaps the problem that the siet is getting to a other service?
luchtmeetnet?
Is there a other option?
Love to have to have this option in domoticz...
antonlamers
Domoticz version: 2021.1
Post by antonlamers »
It doesn't work in my domoticz.
The virtual text sensor say "hello world"
Anton
Greating,
Anton
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
Derik
Post by Derik »
is there perhaps some one that have this script working with the new data...
Hope ...
I like this script for my longs.....
If...
Then i can use my medicine :(
Derik
Post by Derik »
please
Is there a way to use the new data from RIVM?
Love to have this option working..
phoenixblue
Sorry for late response, was working on an other project ;-)
I will look into the new Rivm Data to use it.
Will be continu....
Derik
Post by Derik »
Great!
Thanks...
Other domoticz project??!
phoenixblue
"Other domoticz project??!".... Not at all ;-)
