Change the ON/Off to In /Out or Don't show that text
MYLE
Post by MYLE »
Playing heap Getting Head around it
where in the manual would I find the bit to change the ON / OFF to something else
look in above Image would Like the ON to be replace with the IN and the Off replace with OUT or turn off think the Image tells the story
SweetPants
Re: Change the ON/Off to In /Out or Don't show that text
Post by SweetPants »
MYLE wrote:where in the manual would I find the bit to change the ON / OFF to something else
Nowhere, this is not possible it is hardcoded in the source
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
Maybe you can use a selector switch instead off a switch, and add a level in and out.
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
MYLE
Post by MYLE »
Thanks didnt think of that options
