Domoticz and Kodi Mediacenter on one PI 3?
Posted: Monday 17 April 2017 21:52
by mickeyr61
I have one PI3 and I wondered if it is possible to run Domoticz and Kodi on the same device. I have installed the KAOSBOX image but installing domoticz with sudo curl -L install.domoticz.com | sudo bash does not work.
Re: Domoticz and Kodi Mediacenter on one PI 3?
Posted: Monday 17 April 2017 22:23
by Stray
I have both running. But I started with Raspberry Jessie with domoticz and installed kodi later
Posted: Friday 21 April 2017 14:52
by mickeyr61
Stray wrote:I have both running. But I started with Raspberry Jessie with domoticz and installed kodi later
Yes, that did the trick! I was first installing OpenElec and then tried to install domoticz. Now I first installed (through Noobs) raspbian lite and domoticz (this was very simple) and then kodi. Changing the ports is necessary. Both Domoticz and Kodi use port 8080. I changed the domoticz port.
Now figuring out how to start KODI by boot. But that is not part of this disccussion.
