Domoticz and Kodi Mediacenter on one PI 3?
mickeyr61
I have one PI3 and I wondered if it is possible to run Domoticz and Kodi on the same device. I have installed the KAOSBOX image but installing domoticz with sudo curl -L install.domoticz.com | sudo bash does not work.
Stray
Re: Domoticz and Kodi Mediacenter on one PI 3?
I have both running. But I started with Raspberry Jessie with domoticz and installed kodi later
mickeyr61
Yes, that did the trick! I was first installing OpenElec and then tried to install domoticz. Now I first installed (through Noobs) raspbian lite and domoticz (this was very simple) and then kodi. Changing the ports is necessary. Both Domoticz and Kodi use port 8080. I changed the domoticz port.Stray wrote:I have both running. But I started with Raspberry Jessie with domoticz and installed kodi later
Now figuring out how to start KODI by boot. But that is not part of this disccussion.
