This is what I have - A led lamp switched with TZ66D Z-Wave Switch. I also have a FIBARO System FGMS001-ZW5 Motion Sensor.
I want the lamp to be switched on when motion is deteced.
Can I set this up using association (without using controller logic - controller is not always within reach)?
In other words - can the TZ66D receive signals through Association or can it only send signals through association when the button is pressed?
Thanks for any help!
Association between TZ66D Switch and Fibaro Motion sensor
