Wireless RF Transceiver (Transmitter & Receiver)
Posted: Monday 10 April 2017 10:46
by MYLE
Find this on AliExpress
https://www.aliexpress.com/item/SV613-N ... 2151c9fbc0
Will Domoticz see it Im user Ubuntu
Re: Wireless RF Transceiver (Transmitter & Receiver)
Posted: Monday 10 April 2017 13:25
by i000
Works with Domoticz?
Posted: Monday 10 April 2017 13:46
by gerardvs
In my opinion, most likely not. This is nothing more than a wireless serial extender. Effectively being a long copper wire pair.
Can be very useful but not as a standalone solution to connect to Domoticz.
Posted: Monday 10 April 2017 16:50
by Stuntteam
You can use RFlink with a ser2net solution to have a wireless RF Gateway..
Posted: Monday 10 April 2017 17:21
by b_weijenberg
This transceiver is not supported by Domoticz.
Note that 100mW (+20dBm) is not allowed to use in Europe at 433MHz. The maximum is 10mW ((+10dBm).
RF transceivers also supported by Domoticz are:
PiFace
viewforum.php?f=27
And the USB or LAN RFXCOM (ser2net) RFXtrx433 and RFXtrx433E
viewforum.php?f=44.
For the ser2net configuration see:
viewtopic.php?f=28&t=192&p=65087&hilit=ser2net#p65087
Posted: Monday 10 April 2017 19:28
by i000
Great contribution!
Posted: Monday 10 April 2017 19:37
by MYLE
Thanks guys look like I have more reading to do by the way I'm from New Zealand
Posted: Tuesday 11 April 2017 12:22
by MYLE
Stuntteam wrote:You can use RFlink with a ser2net solution to have a wireless RF Gateway..
Thanks Been reading up on the RFLink i'm leaning down that road
starting to read up on the ser2net also
Just one Question I have some X10 motion 433MHz. I guesting the RFLink will pick them up
Posted: Tuesday 11 April 2017 13:27
by Nautilus
MYLE wrote:Stuntteam wrote:You can use RFlink with a ser2net solution to have a wireless RF Gateway..
http://www.nemcon.nl/blog2/devlist
If it is not on the supported devices list then it a) might work (using of the existing protocols) or b) could be added in some of the later releases. But there's no guarantee it works unless you find it on the supported devices list...
Posted: Tuesday 11 April 2017 17:20
by Stuntteam
X10 works fine.. If you find a device that has issues we will fix it.
