Multiple RFXMeter/Counter Dividers
JMdomotique
Post by JMdomotique »
Good evening..
I don't find a solution to handle my two Electricity counter.
I have two different Electricity counter connected to domoticz.
Both are working but they have different pulses rate by kwh :
* the first one need to divide the pulse by 400 1 Kwh = 400 pulses.
* the second one need to divide the pulse by 100 1 kwh= 100 pulses.
Is there a solution to add a second Energy Meter setting in the Meter/Counter Setup ?
for example :
Energy_1 : 400 cost T1 : 0.2149 / Kwh cost T2 : 0.2149 /kwh
Energy_2 : 100 cost T1 : 0.2149 / Kwh cost T2 : 0.2149 /kwh
this could solve my problem I think ?
In the other hand I have also a fuel oil counter, Is there a solution to add the following line
Fuel oil : 100 cost : 1.6473 /m3
Thank in advance for your help
JMdomotique
Re: Multiple RFXMeter/Counter Dividers
Good evening
hello is there anybody who can help me ???
find here some pictures to give you more precision about my request.
Thanks in advance for your help
My both electricity counter
energy counter.gif (167.86 KiB) Viewed 3167 times
The setting I wish to add in domoticz
mter counter.gif (102.55 KiB) Viewed 3167 times
JMdomotique
is there anybody who could help me ???
Thanks in advance
kimhav
Domoticz version: 2023.2
Post by kimhav »
Hi JMdomotique, Did You ever figure out how to handle two different Count Divider for RFXMeters? Asking since I have the same issue and while I've managed to get the half solution, it would be nice to get the full solution. I've also raised it as a suggestion which might need to addition input and bumping.
