Scripts doesn't work in domoticz
marcotrumpet
Post by marcotrumpet »
Hey guys, I've a problem.
I wrote a script.sh and it works really well in terminal. I set a dummy switch and in the on action I set the script.
#!/bin/sh
# Start Recording RTSP stream via VLC
vlc rtsp://192.168.1.3/unicast --sout=file/mp4:/home/pi/Desktop/Soggiorno-$(date +%m%d%H%M%S).mp4 -I dummy --stop-time=10 vlc://quit
exit 0
that's the script. Already set chmod 777 script.sh and chmod +x script.sh.
In domoticz log I see
Executing script: /home/pi/domoticz/scripts/soggiorno.sh
and no error but nothing happens.
kubrik
Re: Scripts doesn't work in domoticz
Post by kubrik »
If you run in terminal:
sudo /home/pi/domoticz/scripts/soggiorno.sh
it works?
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
marcotrumpet
kubrik wrote:If you run in terminal:
it works?
Yes it works
Inviato dal mio iPhone utilizzando Tapatalk
jannl
Domoticz version: 2022.2
Post by jannl »
Can the script find vlc when started from domoticz?
Verstuurd vanaf mijn SM-G930F met Tapatalk
marcotrumpet
I don't know. How can I know if it does?
Egregius
Domoticz version: v2024.7
Post by Egregius »
Use the absolute path to executables.
Make sure the users that run's Domoticz has rights to the scripts and executables.
Add a echo 'script executed' > /temp/test.log to see of the script is called from domoticz
kubrik
Post by kubrik »
Try to put output to logfile...for example:
vlc rtsp://192.168.1.3/unicast --sout=file/mp4:/home/pi/Desktop/Soggiorno-$(date +%m%d%H%M%S).mp4 -I dummy --stop-time=10 > /home/pi/domoticz/scripts/vlc.log
and look into vlc.log after execution.
A question...but with that vlc command...vlc opens graphically into your desktop?
marcotrumpet
kubrik wrote:Try to put output to logfile...for example:
Log file is empty.
if I start the script in terminal vlc doesn't open graphically
marcotrumpet
it works?
Yes it works
EDIT
I'm sorry I was wrong. If I use SUDO I recive this "VLC is not supposed to be run as root. Sorry.
If you need to use real-time priorities and/or privileged TCP ports
you can use vlc-wrapper (make sure it is Set-UID root and
cannot be run by non-trusted users first)."
Nut starts fine without SUDO
kubrik
Post by kubrik »
Domoticz on raspberry runs as root..so scripts run as root...
You can try this:
sed -i 's/geteuid/getppid/' /usr/bin/vlc
(rif. http://unix.stackexchange.com/questions ... er-in-root)
and run again as root...but make a backup of /usr/bin/vlc before...
Or recompile vlc...
Or use avconf instead of vlc...
marcotrumpet
kubrik wrote:Domoticz on raspberry runs as root..so scripts run as root...
You can try this:
Or recompile vlc...
Yes man! you did it! but now I'm not able to open file due to permission I think.
How can I set permission on file that has (date +%m%d%H%M%S) in the name?
marcotrumpet
You can try this:
Or recompile vlc...
It seems that change permission to folder did the trick
marcotrumpet
Just another problem. I've two scripts calling vlc to record two cameras but domoticz doesn't run them at the same time. If I open two terminals and lunch one script per istance I can do that. I also enabled multiple istances on vlc. Ideas?
marcotrumpet
Done. Simply add an & at the end of the scripts.
Justintime
Post by Justintime »
You can try this:
Or recompile vlc...
Thanks the golden tip.
