Check doors and send command
Posted: Tuesday 04 April 2017 22:49
I use this script to check if my backdoor is open, if so then it wil send a message and set the setpoint to 12°C.
This works good, but i also have front door. If i use the same script for the front door (in total 2 different scripts) only the backdoor working.
When i rename the frontdoor scripts name so the front door is above the backdoor script, only the frontdoor is working.
Can you only run one "time difference" script?
How can i merge this scripts so it checks the back and front door?
-- Automatically adjust heating setpoint to 12 when back door is left open.
t1 = os.time()
s = otherdevices_lastupdate['Achterdeur']
heater = otherdevices_svalues['Toon Thermostaat']
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if (otherdevices['Achterdeur'] == 'Open' and difference > 59 and difference < 65) then
commandArray['SendNotification']='Achterdeur waarschuwing#De Achterdeur staat al meer dan 5 minuten open'
commandArray['UpdateDevice']='335|0|12.00'
print("De Achterdeur staat open, zet de thermostraat op 12 graden celsius")
