Check doors and send command
Martijn85
Domoticz version: Stable
Post by Martijn85 »
I use this script to check if my backdoor is open, if so then it wil send a message and set the setpoint to 12°C.
This works good, but i also have front door. If i use the same script for the front door (in total 2 different scripts) only the backdoor working.
When i rename the frontdoor scripts name so the front door is above the backdoor script, only the frontdoor is working.
Can you only run one "time difference" script?
How can i merge this scripts so it checks the back and front door?
-- Automatically adjust heating setpoint to 12 when back door is left open.
t1 = os.time()
s = otherdevices_lastupdate['Achterdeur']
heater = otherdevices_svalues['Toon Thermostaat']
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if (otherdevices['Achterdeur'] == 'Open' and difference > 59 and difference < 65) then
        commandArray['SendNotification']='Achterdeur waarschuwing#De Achterdeur staat al meer dan 5 minuten open'
        commandArray['UpdateDevice']='335|0|12.00'
        print("De Achterdeur staat open, zet de thermostraat op 12 graden celsius")
tontze
Domoticz version: Beta Ch
Re: Check doors and send command
Post by tontze »
I think other script says door is closed, dont do anything, and other says door open, do something --> conflict ?
Im not guru on these things, so i might be wrong :D
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
emme
Domoticz version: latest
Post by emme »
is the front door a door contact or a simple switch?
the value could change from Open/Closed to On/Off
"We always done this way"
Martijn85
Post by Martijn85 »
emme wrote:is the front door a door contact or a simple switch?
It's a door contact, so it will be open or closed.
Maybe someone can tell me how to putt a second device in the script and check the times for both devices and then send a command for one or both devices if there are longer than 5 minutes open?
Siewert308SW
Post by Siewert308SW »
Maybe something like this
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
	@ script_time_doors.lua
	@ Check doors
-- Time Difference
function timedifference(s)
	t1 = os.time()
	return difference
time_open_max = 300 --300 seconds is 5min
-- Frontdoor
if otherdevices['Voordeur'] == 'Open'
and timedifference(otherdevices_lastupdate['Voordeur']) > time_open_max
then
commandArray['SendNotification']='Voordeur waarschuwing#De voordeur staat al meer dan 5 minuten open'
print("De voordeur staat open, zet de thermostraat op 12 graden celsius")
-- BackDoor
if otherdevices['Achterdeur'] == 'Open'
and timedifference(otherdevices_lastupdate['Achterdeur']) > time_open_max
then
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
gerard76
Domoticz version: 3.8153
Post by gerard76 »
doors               = {'Voordeur','Achterdeur'}
max_open        = 300 -- in seconds
function timedifference(timestamp)
  y, m, d, H, M, S = timestamp:match("(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)")
  return os.difftime(os.time(), os.time{year=y, month=m, day=d, hour=H, min=M, sec=S})
for i, door in pairs(doors) do
  if otherdevices[door] == 'Open' and timedifference(otherdevices_lastupdate[door]) > max_open then
    commandArray['SendNotification'] = 'Waarschuwing#De '..door..' staat al meer dan 5 minuten open'
    print("De "..door.." staat open, zet de thermostraat op 12 graden celsius")
Martijn85
Post by Martijn85 »
Wow! Thanks for sharing, works great guys :D
mvveelen
Post by mvveelen »
Nice, and may come in handy But, what if you receive the message, close the door.....it should return to the old (temp) setting, shouldn't it? So the script might be incomplete to accomplish a full automated system in this case.
