Numerous not used devices Topic is solved
darlomrh
Post by darlomrh »
Hi All,
Not sure if this is normal. I have noticed multiple versions of devices appearing. Last count before I removed them was 92. I have deleted them, rebooted and after a couple of hours, already up to 13 devices.
Is this normal?
I have attached an screenshot.
Screenshot 2017-04-03 at 22.18.00.png (179.47 KiB) Viewed 1694 times
darlomrh
Re: Numerous not used devices
Post by darlomrh »
Update.
Upto 12 ByronSX and 7 LightwaveRF.
Is the issue/feature RFXCom or Domoticz ?
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
You have to disable the "Accept new Hardware Devices" in the settings.
When you want to add new hardware don't forget the "allow for 5 min" button.
Koen
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
darlomrh
Post by darlomrh »
Thanks. Was up to 28 :)
Going to purge and see what happens.
