I get this error : Error: (Controler) 'onMessage' failed 'NameError'. But I can retrieve the name that make this error.
In a python, the name usually follow the error. How could I bring up the faulty name ?
Error Python : Return name Error Topic is solved
- Dnpwwo
Re: Error Python : Return name Error
@St7ven,
The Python framework will return all the information it can but sometimes Python does not make a traceback or the details available.
I would suggest added an error handler something like this around your onMessage function:a construct like that has given me more detail and may help you out.
The 'raise' at the end will pass the error back to Domoticz.
def onMessage(self, Data, Status, Extra):
strData = Data.decode("utf-8", "ignore")
try:
...your code here...
except Exception as inst:
Domoticz.Error("Exception in onMessage, called with Data: '"+str(strData)+"'")
Domoticz.Error("Exception detail: '"+str(inst)+"'")
raise
Thank you Dnpwwo,
It helps a lot !
It helps a lot !
