Help connecting Domoticz and MySensors MTTQ gateway
siddmon
Post by siddmon »
After a lot of reading and trial and error I have the following:
Domoticz + NodeJS + Mosquitto + NodeRed in a Raspberry Pi running Jessie build
Gateway ESP8266MTTQ Client running the default code
And a simple button switch arduino uno
I'm not seeing any values being updated in Domoticz, so I think something is configured incorrectly but don't know what.
There is no error in the log and already tried using the dummy temp device and send a mosquitto_pub from within raspberry pi.
mosquitto_pub -h localhost -m '{ "idx" : 1, "nvalue" : 0, "svalue" : "25.0" }' -t 'domoticz/in'
Also, Domoticz is not displaying the gateway or my node switch.
On the bright side, I can see the messages in the gateway when I press the switch.
2017-03-28 21:19:50.703 Domoticz V3.7196 (c)2012-2017 GizMoCuz
2017-03-28 21:19:50.709 Build Hash: 7a224cd, Date: 2017-03-28 11:40:00
2017-03-28 21:19:50.709 System: Raspberry Pi
2017-03-28 21:19:50.710 Startup Path: /home/pi/domoticz/
2017-03-28 21:19:51.230 PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2017-03-28 21:19:51.292 Active notification Subsystems: gcm, http (2/12)
2017-03-28 21:19:51.319 WebServer(HTTP) started on address: :: with port 8080
2017-03-28 21:19:51.358 WebServer(SSL) started on address: :: with port 443
2017-03-28 21:19:51.364 Proxymanager started.
2017-03-28 21:19:51.372 Starting shared server on: :::6144
2017-03-28 21:19:51.377 TCPServer: shared server started...
2017-03-28 21:19:51.378 RxQueue: queue worker started...
2017-03-28 22:06:32.265 EventSystem: reset all events...
2017-03-28 22:06:32.270 EventSystem: reset all device statuses...
2017-03-28 22:06:32.278 EventSystem: Started
2017-03-28 22:06:33.268 MQTT: Connecting to localhost:1883
2017-03-28 22:06:33.385 MQTT: connected to: localhost:1883
2017-03-28 22:06:33.386 MySensorsMQTT: connected to: localhost:1883
2017-03-28 22:06:33.488 MQTT: Subscribed
2017-03-28 22:07:19.821 Incoming connection from: 192.168.1.5
Can someone explain these different IPs?
// Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
#define MY_IP_ADDRESS 192,168,1,163	//I think this is the static IP that I'm setting for my ESP8266 gateway
// If using static ip you need to define Gateway and Subnet address as well
#define MY_IP_GATEWAY_ADDRESS 192,168,1,1	//Not sure if this is correct
#define MY_IP_SUBNET_ADDRESS 255,255,255,0
// MQTT broker ip address.
#define MY_CONTROLLER_IP_ADDRESS 192,168,1,125		// I think this is the IP address of the rapberry pi running Domoticz
ESP Gateway
 * The MySensors Arduino library handles the wireless radio link and protocol
 * between your home built sensors/actuators and HA controller of choice.
 * The sensors forms a self healing radio network with optional repeaters. Each
 * repeater and gateway builds a routing tables in EEPROM which keeps track of the
 * network topology allowing messages to be routed to nodes.
 * Created by Henrik Ekblad <[email protected]>
 * Copyright (C) 2013-2015 Sensnology AB
 * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
 * Documentation: http://www.mysensors.org
 * Support Forum: http://forum.mysensors.org
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License
 * version 2 as published by the Free Software Foundation.
 * REVISION HISTORY
 * Version 1.0 - Henrik Ekblad
 * DESCRIPTION
 * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
 * LED purposes:
 * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
 * - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
 * - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
 * - ERR (red) - fast blink on error during transmission error or recieve crc error
 * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
 * https://www.mysensors.org/build/connect_radio
 * nRF24L01+  ESP8266
 * VCC        VCC
 * CE         GPIO4
 * CSN/CS     GPIO15
 * SCK        GPIO14
 * MISO       GPIO12
 * MOSI       GPIO13
 * Not all ESP8266 modules have all pins available on their external interface.
 * This code has been tested on an ESP-12 module.
 * The ESP8266 requires a certain pin configuration to download code, and another one to run code:
 * - Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch')
 * - Connect GPIO15 via 10K pulldown resistor to GND
 * - Connect CH_PD via 10K resistor to VCC
 * - Connect GPIO2 via 10K resistor to VCC
 * - Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch')
  * Inclusion mode button:
 * - Connect GPIO5 via switch to GND ('inclusion switch')
 * Hardware SHA204 signing is currently not supported!
 * Make sure to fill in your ssid and WiFi password below for ssid & pass.
// Enable debug prints to serial monitor
#define MY_DEBUG
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
#define MY_BAUD_RATE 9600
// Enables and select radio type (if attached)
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
#define MY_GATEWAY_MQTT_CLIENT
#define MY_GATEWAY_ESP8266
// Set this node's subscribe and publish topic prefix
#define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/MyMQTT"
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/MyMQTT"
// Set MQTT client id
#define MY_MQTT_CLIENT_ID "mysensors-1"
// Enable these if your MQTT broker requires usenrame/password
//#define MY_MQTT_USER "username"
//#define MY_MQTT_PASSWORD "password"
// Set WIFI SSID and password
#define MY_ESP8266_SSID "xxxxxxxxx"          // "MySSID" - removed
#define MY_ESP8266_PASSWORD "xxxxxxxxxxxx"   // "MyVerySecretPassword" - removed
// Set the hostname for the WiFi Client. This is the hostname
// it will pass to the DHCP server if not static.
// #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
// The MQTT broker port to to open
#define MY_PORT 1883
// Enable inclusion mode
#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
#define MY_INCLUSION_BUTTON_FEATURE
// Set inclusion mode duration (in seconds)
#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
#define MY_INCLUSION_MODE_BUTTON_PIN  3
// Set blinking period
#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
#define MY_DEFAULT_ERR_LED_PIN 16  // Error led pin
#define MY_DEFAULT_RX_LED_PIN  16  // Receive led pin
#define MY_DEFAULT_TX_LED_PIN  16  // the PCB, on board LED
#include <ESP8266WiFi.h>
#include <MySensors.h>
void setup()
void presentation()
	// Present locally attached sensors here
void loop()
	// Send locally attech sensors data here
// MY_MQTT_PUBLISH_TOPIC_PREFIX/FROM-NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
Node with switch sensor
 * DESCRIPTION
 * Simple binary switch example
 * Connect button or door/window reed switch between
 * digitial I/O pin 3 (BUTTON_PIN below) and GND.
 * http://www.mysensors.org/build/binary
#define MY_DEBUG
//#define MY_NODE_ID 6
// Enable and select radio type attached
#include <SPI.h>
#include <Bounce2.h>
#define CHILD_ID 3
#define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
Bounce debouncer = Bounce();
int oldValue=-1;
// Change to V_LIGHT if you use S_LIGHT in presentation below
MyMessage msg(CHILD_ID,V_TRIPPED);
void setup()
  // Setup the button
  pinMode(BUTTON_PIN,INPUT);
  // Activate internal pull-up
  digitalWrite(BUTTON_PIN,HIGH);
  // After setting up the button, setup debouncer
  debouncer.attach(BUTTON_PIN);
  debouncer.interval(5);
    Serial.begin(9600);        // initialize serial
void presentation() {
  // Register binary input sensor to gw (they will be created as child devices)
  // You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage.
  // If S_LIGHT is used, remember to update variable type you send in. See "msg" above.
  present(CHILD_ID, S_DOOR);
//  Check if digital input has changed and send in new value
void loop()
  debouncer.update();
  // Get the update value
  int value = debouncer.read();
    Serial.println(value);
  if (value != oldValue) {
     // Send in the new value
     send(msg.set(value==HIGH ? 1 : 0));
     oldValue = value;
     digitalWrite(13,value);
ESP output
;255;3;0;9;TSF:MSG:BC
0;255;3;0;9;TSF:MSG:FPAR REQ,ID=6
0;255;3;0;9;TSF:PNG:SEND,TO=0
0;255;3;0;9;TSF:CKU:OK
0;255;3;0;9;TSF:MSG:GWL OK
0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
..0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
0;255;3;0;9;TSF:MSG:PINGED,ID=6,HP=1
0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
....0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=2,l=2,sg=0:1
.........................................0;255;3;0;9;TSF:SRT:OK
0;255;3;0;9;TSF:SAN:OK
.........0;255;3;0;9;TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
0;255;3;0;9;TSF:MSG:BC
..............0;255;3;0;9;TSM:READY:NWD REQ
0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
............0;255;3;0;9;TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
...0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
.........................0;255;3;0;9;TSM:READY:NWD REQ
......................0;255;3;0;9;TSF:SAN:OK
.0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
Switch Node output
60 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.2.0-beta
4 TSM:INIT
4 TSF:WUR:MS=0
11 TSM:INIT:TSP OK
13 TSF:SID:OK,ID=6
15 TSM:FPAR
51 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
309 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
314 TSF:MSG:FPAR OK,ID=0,D=1
2058 TSM:FPAR:OK
2059 TSM:ID
2060 TSM:ID:OK
2062 TSM:UPL
2065 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
2173 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
2178 TSF:MSG:PONG RECV,HP=1
2181 TSM:UPL:OK
2182 TSM:READY:ID=6,PAR=0,DIS=1
2187 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
2320 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
2327 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
2336 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
4343 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
4349 MCO:REG:REQ
4353 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
4473 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
4478 MCO:PIM:NODE REG=1
4481 MCO:BGN:STP
Domoticz is configures as following:
3 dummy Yes Dummy (Does nothing, use for virtual switches only) Create Virtual Sensors Disabled
2 MyDomoAtHome Yes MySensors Gateway with MQTT interface
Version: ? Setup localhost 1883 Disabled
Any help making the setup work is appreciated
mack
Domoticz version: Stable
Re: Help connecting Domoticz and MySensors MTTQ gateway
Post by mack »
