problems installing nodejs in raspberry pi
Posted: Wednesday 29 March 2017 5:24
by siddmon
When I run : curl -sL https://deb.nodesource.com/setup | sudo bash -
I get the following messages:
                         SCRIPT DEPRECATION WARNING
  This script, located at https://deb.nodesource.com/setup, used to
  install Node.js v0.10, is being deprecated and will eventually be made
  inactive.
  You should use the script that corresponds to the version of Node.js you
  wish to install. e.g.
   * https://deb.nodesource.com/setup_4.x — Node.js v4 LTS "Argon" (recommended)
   * https://deb.nodesource.com/setup_6.x — Node.js v6 Current
  Please see https://github.com/nodejs/LTS/ for details about which version
  may be appropriate for you.
  The NodeSource Node.js Linux distributions GitHub repository contains
  information about which versions of Node.js and which Linux distributions
  are supported and how to use the install scripts.
    https://github.com/nodesource/distributions
pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_4.x  | sudo bash -
## Installing the NodeSource Node.js v4.x LTS Argon repo...
## You appear to be running on ARMv6 hardware. Unfortunately this is not currently supported by the NodeSource Linux distributions. Please use the 'linux-armv6l' binary tarballs available directly from nodejs.org for Node.js v4 and later.
I already tried just sudo apt-get nodejs and it gets installed but node —version and nmp command and the bash says "command not found"
Re: problems installing nodejs in raspberry pi
Posted: Wednesday 29 March 2017 8:42
by siddmon
found the solution
http://blog.wia.io/installing-node-js-v ... pberry-pi/
Also installing Node-Red will install node js
