I get the following messages:
SCRIPT DEPRECATION WARNING
This script, located at https://deb.nodesource.com/setup, used to
install Node.js v0.10, is being deprecated and will eventually be made
inactive.
You should use the script that corresponds to the version of Node.js you
wish to install. e.g.
* https://deb.nodesource.com/setup_4.x — Node.js v4 LTS "Argon" (recommended)
* https://deb.nodesource.com/setup_6.x — Node.js v6 Current
Please see https://github.com/nodejs/LTS/ for details about which version
may be appropriate for you.
The NodeSource Node.js Linux distributions GitHub repository contains
information about which versions of Node.js and which Linux distributions
are supported and how to use the install scripts.
https://github.com/nodesource/distributions
pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_4.x | sudo bash -
## Installing the NodeSource Node.js v4.x LTS Argon repo...
## You appear to be running on ARMv6 hardware. Unfortunately this is not currently supported by the NodeSource Linux distributions. Please use the 'linux-armv6l' binary tarballs available directly from nodejs.org for Node.js v4 and later.
