Hello!
I now use Automate (Android) and JSON URL's to do some switch actions, but I would like to start an Event I made in Domoticz.
So, is it possible to call for an Event via an JSON URL?
Json URL for Event? Topic is solved
Re: Json URL for Event?
I'm not sure if you can trigger an event directly from Json URL, however you could create a virtual switch, switch that with Json, and use it in the event / blocky.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
Events always run. They perform the way you make them. Only switches, groups and scenes can be triggered.
Thanks, didn't think of that one.sion wrote:I'm not sure if you can trigger an event directly from Json URL, however you could create a virtual switch, switch that with Json, and use it in the event / blocky.
Jut what I needed
