Hue scene are shown as switch
Blueone
In the past I added some scenes in de devices tab from domoticz and is where also scene's in domoticz. Now they are shown as switches in domoticz with an on and off and not as scene. Does someknow know what is going wrong here? They also don't turn of when I switch between scenes. Does someknow what I'm doing wrong because it worked in the past?
sion
Re: Hue scene are shown as switch
I have never known hue scenes to show in the domoticz scenes page. Form some reason I always had trouble adding hue scenes from the devices tab. Normal scenes would work ok, but any with fade in etc didn't work once added - so I tend to create a virtual switch and trigger the scene on the hue hub with a bash script..... it I digress.
It shouldn't matter that the switch doesn't turn off, as you can still turn it on, even if it's already on. But it may make more sense to click on edit on the switch, and change the switch type to "push on button"
How that helps.
How that helps.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
sion
I have never known hue scenes to show in the domoticz scenes page. It normally as push on buttons in the main switches page.
For some reason I always had trouble adding hue scenes from the devices tab. Normal scenes would work ok, but any with fade in etc didn't work once added - so I tend to create a virtual switch and trigger the scene on the hue hub with a bash script..... but I digress.
How that helps.
How that helps.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
Blueone
Oke thanks, i'm going to do it with the script know. But I don't really understand why adding of hue scenes directly was removed. But at the end, is works, better dan no integration
